Hi friends!
I'm developing my first plugin, it should communicate with my main python script on my RPi using queues and the Manager class from the multiprocessing library (https://docs.python.org/3/library/multiprocessing.html#using-a-remote-manager). This works as intended, however, octoprint crashes during shutdown:
Terminal after Ctrl+C for aborting (initally started with "octoprint serve"). The first Ctrl+C kind of deadlocks, the second shows the error:
^C^CException ignored in: <module 'threading' from '/usr/lib/python3.7/threading.py'>
File "/usr/lib/python3.7/threading.py", line 1281, in _shutdown
t.join()
File "/usr/lib/python3.7/threading.py", line 1032, in join
self._wait_for_tstate_lock()
File "/usr/lib/python3.7/threading.py", line 1048, in _wait_for_tstate_lock
elif lock.acquire(block, timeout):
KeyboardInterrupt
2020-04-21 22:13:02,444 - octoprint.server - INFO - Shutting down...
Simplified init.py
During start up a process with the manager class from multiprocessing is started. The subsequent loop usually waits for an update in the queue, however, the queue was removed for testing purposes.
I tried to solve the problem both with a "finally" statement in on_after_startup and in on_shutdown. But octoprint deadlocks with this _wait_for_tstate_lock before either is called.
#!/usr/bin/python3
import octoprint.plugin
from multiprocessing.managers import BaseManager
from multiprocessing import Process, Queue, active_children
from time import sleep
class NabuPlugin(octoprint.plugin.TemplatePlugin,
octoprint.plugin.AssetPlugin,
octoprint.plugin.SimpleApiPlugin,
octoprint.plugin.StartupPlugin,
octoprint.plugin.ShutdownPlugin):
def _start_queue_server(self):
class QueueManager(BaseManager): pass
m = QueueManager(address=('', 33334), authkey=b'prusaprinter')
s = m.get_server()
s.serve_forever()
def get_api_commands(self):
return dict(
nabu=[]
def on_after_startup(self):
self._logger.info("Nabu started, start server!!!!!!!!!!!!!!!!!!!!!!!!!!!!")
try:
# start server for feedback
proc = Process(target=self._start_queue_server)
proc.start()
while True:
sleep(10)
self._logger.info("Loop")
except:
self._logger.info("unexpected exception!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!")
finally:
# close all processes (i. e. server process)
for sub in active_children():
self._logger.info("shutting down process !!!!!!!!!!!!!!!!!!!!!!!!!!!", sub)
sub.terminate()
sub.join()
self._logger.info("all done !!!!!!!!!!!!!!!!!!!!!!!!!!!!")
def on_shutdown(self):
self._logger.info("Nabu shutting down process", sub)
sub.terminate()
sub.join()
__plugin_name__ = "NaBu - Navbar Button"
__plugin_pythoncompat__ = ">=3,<4"
def __plugin_load__():
global __plugin_implementation__
__plugin_implementation__ = NabuPlugin()
The octoprint log is silent:
2020-04-21 22:12:29,852 - octoprint.startup - INFO - ******************************************************************************
2020-04-21 22:12:29,854 - octoprint.startup - INFO - Starting OctoPrint 1.4.0
2020-04-21 22:12:29,855 - octoprint.startup - INFO - ******************************************************************************
2020-04-21 22:12:30,249 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2020-04-21 22:12:30,253 - octoprint.startup - INFO - Blacklist processing done, adding 1 blacklisted plugin versions: roomtemp (any)
2020-04-21 22:12:30,302 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-04-21 22:12:30,393 - octoprint.plugin.core - INFO - Plugin Discovery is disabled.
2020-04-21 22:12:30,985 - octoprint.plugin.core - INFO - Plugin Virtual Printer is disabled.
2020-04-21 22:12:31,023 - octoprint.plugin.core - INFO - Plugin Anonymous Usage Tracking is disabled.
2020-04-21 22:12:31,135 - octoprint.plugin.core - INFO - Plugin Error Tracking is disabled.
2020-04-21 22:12:31,414 - octoprint.plugin.core - INFO - Found 16 plugin(s) providing 12 mixin implementations, 26 hook handlers
2020-04-21 22:12:31,543 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-04-21 22:12:31,551 - octoprint.server - INFO - Intermediary server started
2020-04-21 22:12:31,551 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-04-21 22:12:31,610 - octoprint.plugin.core - INFO - Found 16 plugin(s) providing 12 mixin implementations, 26 hook handlers
2020-04-21 22:12:31,659 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-04-21 22:12:31,918 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-04-21 22:12:31,922 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: "Need(method='role', value='plugin_action_command_prompt_interact')")
2020-04-21 22:12:31,923 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: "Need(method='role', value='plugin_announcements_read')")
2020-04-21 22:12:31,923 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: "Need(method='role', value='plugin_announcements_read'), Need(method='role', value='plugin_announcements_manage')")
2020-04-21 22:12:31,924 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: "Need(method='role', value='plugin_appkeys_admin')")
2020-04-21 22:12:31,924 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: "Need(method='role', value='plugin_backup_access')")
2020-04-21 22:12:31,925 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: "Need(method='role', value='plugin_logging_manage')")
2020-04-21 22:12:31,925 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: "Need(method='role', value='plugin_pi_support_check')")
2020-04-21 22:12:31,925 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: "Need(method='role', value='plugin_pluginmanager_manage')")
2020-04-21 22:12:31,926 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: "Need(method='role', value='plugin_pluginmanager_install'), Need(method='role', value='plugin_pluginmanager_manage')")
2020-04-21 22:12:31,926 - octoprint.server - INFO - Added new permission from plugin printer_safety_check: PLUGIN_PRINTER_SAFETY_CHECK_DISPLAY (needs: "Need(method='role', value='plugin_printer_safety_check_display')")
2020-04-21 22:12:31,927 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: "Need(method='role', value='plugin_softwareupdate_check')")
2020-04-21 22:12:31,927 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: "Need(method='role', value='plugin_softwareupdate_update')")
2020-04-21 22:12:32,833 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2020-04-21 22:12:33,720 - octoprint.util.pip - INFO - Version of pip is 20.0.2
2020-04-21 22:12:33,722 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-04-21 22:12:33,723 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-04-21 22:12:33,753 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-04-21 22:12:33,760 - octoprint.plugin.core - INFO - Initialized 12 plugin implementation(s)
2020-04-21 22:12:33,766 - octoprint.plugin.core - INFO - 16 plugin(s) registered with the system:
| Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements
| !Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys
| Backup & Restore (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup
| Core Wizard (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/corewizard
| !Discovery (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/discovery
| !Error Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking
| Logging (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging
| Login UI (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/loginui
| NaBu - Navbar Button (1.0.0) = /home/pi/OctoPrint-nabu/octoprint_nabu
| Pi Support Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager
| Printer Safety Check (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/printer_safety_check
| Software Update (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate
| !Virtual Printer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/virtual_printer
Prefix legend: ! = disabled, # = blacklisted, * = incompatible
2020-04-21 22:12:33,779 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 917008384
| os:
| platform: linux
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
| octopi_version: 0.17.0
| python:
| pip: 20.0.2
| version: 3.7.3
| virtualenv: /home/pi/oprint
2020-04-21 22:12:33,787 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-04-21 22:12:33,790 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-04-21 22:12:34,326 - octoprint.server - INFO - Shutting down intermediary server...
2020-04-21 22:12:34,468 - octoprint.server - INFO - Intermediary server shut down
2020-04-21 22:12:34,471 - octoprint.events - INFO - Processing startup event, this is our first event
2020-04-21 22:12:34,471 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2020-04-21 22:12:34,472 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-04-21 22:12:34,474 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2020-04-21 22:12:34,481 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-04-21 22:12:34,522 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-04-21 22:12:35,594 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-04-21 22:12:35,611 - octoprint.server - INFO - Trying to connect to configured serial port None
2020-04-21 22:12:35,668 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2020-04-21 22:12:35,673 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-04-21 22:12:35,676 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-04-21 22:12:35,707 - octoprint.server - INFO - Listening on http://0.0.0.0:5000 and http://[::]:5000
2020-04-21 22:12:35,758 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-04-21 22:12:36,817 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2020-04-21 22:12:36,824 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-04-21 22:12:36,824 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-04-21 22:12:36,892 - octoprint.plugins.nabu - INFO - Nabu started, start server!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2020-04-21 22:12:37,059 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-04-21 22:12:37,101 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.20
2020-04-21 22:12:37,170 - octoprint.server.util.flask - INFO - Passively logging in user _admin from ::ffff:192.168.178.20
2020-04-21 22:12:37,171 - octoprint.access.users - INFO - Logged in user: _admin
2020-04-21 22:12:38,050 - octoprint.server.util.sockjs - INFO - User _admin logged in on the socket from client ::ffff:192.168.178.20
2020-04-21 22:12:41,038 - octoprint.util.comm - INFO - Could not enter programming mode on /dev/ttyACM0: 'Timeout'
2020-04-21 22:12:41,046 - octoprint.util.comm - INFO - Could not enter programming mode on /dev/ttyS0: 'Failed to open serial port'
2020-04-21 22:12:41,049 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-04-21 22:12:46,957 - octoprint.plugins.nabu - INFO - Loop
2020-04-21 22:12:56,968 - octoprint.plugins.nabu - INFO - Loop
2020-04-21 22:13:02,697 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2020-04-21 22:13:02,701 - octoprint.events - INFO - Event loop shut down
2020-04-21 22:13:02,703 - octoprint.server - INFO - Goodbye!
Any help would be appreciated, this is my first python project ever
. The solution is probably very simple.
