fresh log file below, near the bottom i see a print_failed line. and i have noticed that all my time lapse videos have a -failed on the end......weird
2020-08-15 16:51:46,781 - octoprint.startup - INFO - ******************************************************************************
2020-08-15 16:51:46,782 - octoprint.startup - INFO - Starting OctoPrint 1.4.2
2020-08-15 16:51:46,783 - octoprint.startup - INFO - ******************************************************************************
2020-08-15 16:51:52,121 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2020-08-15 16:51:52,146 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2020-08-15 16:51:52,148 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is working
2020-08-15 16:51:52,149 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2020-08-15 16:51:52,707 - octoprint.startup - INFO - Blacklist processing done, adding 10 blacklisted plugin versions: roomtemp (any), GcodeEditor (0.1.1), GcodeEditor (0.2.0), GcodeEditor (0.2.1), GcodeEditor (0.2.2), GcodeEditor (0.2.3), GcodeEditor (0.2.4), GcodeEditor (0.2.5), GcodeEditor (0.2.6), GcodeEditor (0.2.8)
2020-08-15 16:51:52,727 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-08-15 16:51:53,436 - octoprint.plugin.core - INFO - Plugin SlicerSettingsTab (1.0.3) is disabled.
2020-08-15 16:51:53,519 - octoprint.plugin.core - INFO - Plugin Active Filters Extended (0.1.0) is disabled.
2020-08-15 16:51:53,566 - octoprint.plugin.core - INFO - Plugin Octolapse (0.3.4) is disabled.
2020-08-15 16:51:53,606 - octoprint.plugin.core - INFO - Plugin DisplayLayerProgress Plugin (1.20.0) is disabled.
2020-08-15 16:51:53,625 - octoprint.plugin.core - INFO - Plugin Bed Visualizer (0.1.13) is disabled.
2020-08-15 16:51:53,643 - octoprint.startup - INFO - Added settings overlay from plugin consolidate_temp_control
2020-08-15 16:51:53,644 - octoprint.plugin.core - INFO - Found 37 plugin(s) providing 32 mixin implementations, 50 hook handlers
2020-08-15 16:51:53,816 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-08-15 16:51:53,831 - octoprint.server - INFO - Intermediary server started
2020-08-15 16:51:53,832 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-08-15 16:51:53,917 - octoprint.plugin.core - INFO - Found 37 plugin(s) providing 32 mixin implementations, 50 hook handlers
2020-08-15 16:51:53,933 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-08-15 16:51:54,155 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-08-15 16:51:54,157 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2020-08-15 16:51:54,158 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2020-08-15 16:51:54,159 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-08-15 16:51:54,160 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-08-15 16:51:54,160 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-08-15 16:51:54,162 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-08-15 16:51:54,162 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-08-15 16:51:54,163 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2020-08-15 16:51:54,164 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-08-15 16:51:54,165 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-08-15 16:51:54,165 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-08-15 16:51:54,166 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-08-15 16:51:54,167 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-08-15 16:51:54,168 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-08-15 16:51:54,326 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-08-15 16:51:54,931 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-15 16:51:55,528 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2020-08-15 16:51:55,529 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-08-15 16:51:55,530 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-08-15 16:51:55,534 - octoprint.plugin.core - INFO - Initialized 32 plugin implementation(s)
2020-08-15 16:51:55,544 - octoprint.plugins.gcodesystemcommands - INFO - Add command definition OCTO90 = sudo shutdown -h now
2020-08-15 16:51:55,554 - octoprint.plugins.psucontrol - INFO - Using GPIO for On/Off
2020-08-15 16:51:55,554 - octoprint.plugins.psucontrol - INFO - Using GPIO for tracking PSU on/off state.
2020-08-15 16:51:55,555 - octoprint.plugins.psucontrol - INFO - Running RPi.GPIO version 0.7.0
2020-08-15 16:51:55,556 - octoprint.plugins.psucontrol - INFO - Using GPIO sensing to determine PSU on/off state.
2020-08-15 16:51:55,556 - octoprint.plugins.psucontrol - INFO - Configuring GPIO for pin 40
2020-08-15 16:51:55,557 - octoprint.plugins.psucontrol - INFO - Using GPIO for On/Off
2020-08-15 16:51:55,557 - octoprint.plugins.psucontrol - INFO - Configuring GPIO for pin 40
2020-08-15 16:51:55,563 - octoprint.plugin.core - INFO - 37 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
| Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
| Active Filters (0.0.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_active_filters
| !Active Filters Extended (0.1.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_active_filters_extended
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/announcements
| Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/appkeys
| Automatic Shutdown (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_automaticshutdown
| Autoselect Plugin (0.3.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_autoselect
| Backup & Restore (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/backup
| !Bed Visualizer (0.1.13) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| Consolidate Temp Control (0.1.7) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_consolidate_temp_control
| Core Wizard (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/corewizard
| Discovery (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/discovery
| !DisplayLayerProgress Plugin (1.20.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_DisplayLayerProgress
| Dragon Order (0.1.5) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_dragon_order
| Error Tracking (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/errortracking
| File Check (2020.8.7) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_file_check
| Firmware Check (2020.6.22) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check
| GCODE System Commands (1.0.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_gcodesystemcommands
| GCode Viewer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
| Logging (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/logging
| Login UI (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/loginui
| Macro (0.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_macro
| Navbar Temperature Plugin (0.14) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_navbartemp
| !Octolapse (0.3.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse
| OctoPrint-WideScreen (0.1.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_widescreen
| Pi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
| Preheat Button (0.5.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_preheat
| PSU Control (0.1.9) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_psucontrol
| Python 3 Check (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_python3plugincompatibilitycheck
| !SlicerSettingsTab (1.0.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_SlicerSettingsTab
| Software Update (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
| Tab Order (0.5.10) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_taborder
| TouchUI (0.3.15) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_touchui
| Virtual Printer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
Prefix legend: ! = disabled, # = blacklisted, * = incompatible
2020-08-15 16:51:55,574 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1500.0
| ram: 4041703424
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 4 Model B Rev 1.2
| octopi_version: 0.17.0
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2020-08-15 16:51:55,583 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-08-15 16:51:55,603 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-08-15 16:51:56,240 - octoprint.server - INFO - Shutting down intermediary server...
2020-08-15 16:51:56,643 - octoprint.server - INFO - Intermediary server shut down
2020-08-15 16:51:56,645 - octoprint.events - INFO - Processing startup event, this is our first event
2020-08-15 16:51:56,646 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2020-08-15 16:51:56,652 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-08-15 16:51:56,660 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-08-15 16:51:56,660 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-08-15 16:51:56,662 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-08-15 16:51:56,737 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-08-15 16:51:56,848 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "Creality Ender-5"' for _http._tcp
2020-08-15 16:51:56,906 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "Creality Ender-5"' for _octoprint._tcp
2020-08-15 16:51:56,967 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "Creality Ender-5" for SSDP
2020-08-15 16:51:57,358 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-08-15 16:51:58,014 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-08-15 16:51:58,631 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-08-15 16:51:58,633 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-08-15 16:51:58,633 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-08-15 16:51:58,638 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 3.6GB. That is considered sufficient for updating.
2020-08-15 16:51:58,648 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-08-15 16:51:59,071 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-08-15 16:51:59,301 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.100
2020-08-15 16:51:59,312 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.0.120/'}
2020-08-15 16:51:59,479 - octoprint.server.util.flask - INFO - Passively logging in user HtRabbit from ::ffff:192.168.0.100
2020-08-15 16:51:59,481 - octoprint.access.users - INFO - Logged in user: HtRabbit
2020-08-15 16:51:59,482 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2020-08-15 16:51:59,609 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@250000
2020-08-15 16:51:59,611 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 250000
2020-08-15 16:51:59,613 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 250000
2020-08-15 16:51:59,660 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'python': '2.7.16', 'ram': 4041703424L, u'octopi_version': u'0.17.0', 'version': u'1.4.2', 'pip': '19.3.1', 'cores': 4, 'freq': 1500.0, u'pi_model': u'Raspberry Pi 4 Model B Rev 1.2', 'os': 'linux'}
2020-08-15 16:51:59,672 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2020-08-15 16:51:59,724 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-08-15 16:52:00,056 - octoprint.server.util.sockjs - INFO - User HtRabbit logged in on the socket from client ::ffff:192.168.0.100
2020-08-15 16:52:00,333 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2020-08-15 16:52:00,345 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-08-15 16:52:02,328 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin bugfix-2.0.x (GitHub)"
2020-08-15 16:52:02,341 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2020-08-15 16:52:05,325 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 5}
2020-08-15 16:52:05,895 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'python': '2.7.16', 'ram': 4041703424L, u'octopi_version': u'0.17.0', 'version': u'1.4.2', u'plugins': u'active_filters:0.0.1,python3plugincompatibilitycheck:0.1.4,autoselect:0.3.0,dragon_order:0.1.5,taborder:0.5.10,touchui:0.3.15,automaticshutdown:0.1.4,gcodesystemcommands:1.0.1,macro:0.2.0,navbartemp:0.14,widescreen:0.1.3,consolidate_temp_control:0.1.7,psucontrol:0.1.9,preheat:0.5.1', 'pip': '19.3.1', 'cores': 4, 'freq': 1500.0, u'pi_model': u'Raspberry Pi 4 Model B Rev 1.2', 'os': 'linux'}
2020-08-15 16:52:06,089 - octoprint.server.preemptive_cache - INFO - ... done in 6.78s
2020-08-15 16:52:06,423 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {u'printer_baudrate': 250000, u'printer_port': None, 'firmware_name': u'Marlin bugfix-2.0.x (GitHub)'}
2020-08-15 16:52:28,986 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: gcode_test.gcode, owner: HtRabbit, user: HtRabbit
2020-08-15 16:52:29,002 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-08-15 16:52:29,009 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: gcode_test.gcode, owner: HtRabbit, user: HtRabbit
2020-08-15 16:52:29,064 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-08-15 16:52:29,089 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-08-15 16:52:29,093 - octoprint.plugins.psucontrol - INFO - Auto-On - Turning PSU On (Triggered by G28)
2020-08-15 16:52:29,095 - octoprint.plugins.psucontrol - INFO - Switching PSU On
2020-08-15 16:52:29,732 - octoprint.plugins.tracking - INFO - Sent tracking event print_started, payload: {'origin': u'local', 'file': 'b34fa6ee77b876ecf37e4184a2869497fdf07c64'}
2020-08-15 16:52:36,212 - octoprint.util.comm - INFO - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2020-08-15 16:52:56,643 - octoprint.util.comm - INFO - Telling the printer to set the busy interval to our "communicationBusy" timeout - 1s = 2s
2020-08-15 16:52:56,947 - octoprint.plugins.psucontrol - INFO - Switching PSU Off
2020-08-15 16:52:56,984 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Offline"
2020-08-15 16:52:57,007 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2020-08-15 16:52:57,334 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2020-08-15 16:52:57,355 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@250000
2020-08-15 16:52:57,363 - tornado.access - WARNING - 409 GET /api/printer?history=false&limit=0&exclude=sd (127.0.0.1) 6.28ms
2020-08-15 16:52:57,366 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 250000
2020-08-15 16:52:57,374 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 250000
2020-08-15 16:52:57,396 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2020-08-15 16:52:57,402 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-08-15 16:52:57,653 - octoprint.plugins.tracking - INFO - Sent tracking event print_failed, payload: {'origin': u'local', u'reason': u'error', u'commerror_text': u'', 'file': 'b34fa6ee77b876ecf37e4184a2869497fdf07c64', u'elapsed': 27}
2020-08-15 16:52:59,161 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2020-08-15 16:52:59,182 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-08-15 16:53:01,119 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin bugfix-2.0.x (GitHub)"
2020-08-15 16:53:01,151 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2020-08-15 16:53:01,646 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {u'printer_baudrate': 250000, u'printer_port': None, 'firmware_name': u'Marlin bugfix-2.0.x (GitHub)'}
2020-08-15 16:53:02,115 - octoprint.plugins.automaticshutdown - INFO - Waiting for 1 timelapse(s) to finish rendering before starting shutdown timer...
2020-08-15 16:53:07,121 - octoprint.plugins.automaticshutdown - INFO - Waiting for 1 timelapse(s) to finish rendering before starting shutdown timer...
2020-08-15 16:53:12,126 - octoprint.plugins.automaticshutdown - INFO - Waiting for 1 timelapse(s) to finish rendering before starting shutdown timer...
2020-08-15 16:53:17,130 - octoprint.plugins.automaticshutdown - INFO - Waiting for 1 timelapse(s) to finish rendering before starting shutdown timer...
2020-08-15 16:53:22,136 - octoprint.plugins.automaticshutdown - INFO - Waiting for 1 timelapse(s) to finish rendering before starting shutdown timer...
2020-08-15 16:53:27,158 - octoprint.plugins.automaticshutdown - INFO - Waiting for 1 timelapse(s) to finish rendering before starting shutdown timer...
2020-08-15 16:53:32,164 - octoprint.plugins.automaticshutdown - INFO - Waiting for 1 timelapse(s) to finish rendering before starting shutdown timer...
2020-08-15 16:53:37,171 - octoprint.plugins.automaticshutdown - INFO - Waiting for 1 timelapse(s) to finish rendering before starting shutdown timer...
