Home Assistant component for Mosaic Palette and Canvas Hub Octoprint plug-ins
Yeah, that's the rub. I don't have my printer close to my machine. I have to unplug my laptop from power, and all the other random stuff plugged in and take it to the printer to upgrade or unload all the filament, disconnect from my printer and more the palette back to my work area. It's just an inconvenience.
Just noticed on their release notes that there were api commands added for OctoPod for getting ping history. With Home Assitant you can do API calls if I'm not mistaken. You may want to look into that downloadPingHistory and getPingHistory commands.
Edit: Quick test and it does seem to respond, but because I'm not printing there's a lot of empty stuff I suspect.
The API seems to have a bunch of other stuff you can do, and what I assume is being used to control the palette from their plugin interface.
    def get_api_commands(self):
        return dict(
            clearPalette2=[],
            connectOmega=["port"],
            disconnectPalette2=[],
            sendCutCmd=[],
            uiUpdate=[],
            changeAlertSettings=["condition"],
            displayPorts=["condition"],
            sendErrorReport=["errorNumber", "description"],
            startPrint=[],
            changeAutoVariationCancelPing=["condition"],
            changeVariationPct=["value"],
            changeVariationPingStart=["value"],
            changeShowPingOnPrinter=["condition"],
            changeFeedRateControl=["condition"],
            changeFeedRateSlowed=["condition"],
            changeFeedRateNormalPct=["value"],
            changeFeedRateSlowPct=["value"],
            startAutoLoad=[],
            downloadPingHistory=[],
            getPingHistory=[],
            changeAutoStartAfterLoad=["condition"]
That's great dude. Thanks for forwarding this. I looked quickly at the GitLab, but did not even get that far.
Yes, Home Assistant can do API calls easily. This could be the way!
Pings are in there and so are the feed rates. Can't find anything relating to splices though... Will have a proper look when work is over.
@jneilliii
Trying my best (ie not much) to get to the bottom of this. I can access the printer's API calls like this:
  - platform: rest
    resource: 'http://X.X.X.X/api/job'
    value_template: '{{ value_json.job.file.name }}'
    headers:
      X-Api-Key: XXX
I tried to emulate this inspired by your post:
  - platform: rest
    resource: 'http://X.X.X.X/api/plugin/palette2'
    method: POST
    payload: '{ "changeFeedRateSlowed" }'
    headers:
      X-Api-Key: XXX
This results in an error due to size exceeding 255 characters (limitation of Home Assistant). I need to break this down into different attributes.
Is there a way to see all the JSON attributes as I would for http://X.X.X.X/api/job? This yields:
  "job": {
    "averagePrintTime": 78057.953208101,
    "estimatedPrintTime": 81414.84215168528,
    "filament": {
      "tool0": {
        "length": 157101.32940980978,
        "volume": 377.8729802313965
    "file": {
      "date": 1581240663,
      "display": "Solar System Scale New.mcf.gcode",
      "name": "Solar_System_Scale_New.mcf.gcode",
      "origin": "local",
      "path": "Solar_System_Scale_New.mcf.gcode",
      "size": 27556894
    "lastPrintTime": 78057.953208101,
    "user": null
  "progress": {
    "completion": 36.105959546819754,
    "filepos": 9949681,
    "printTime": 27298,
    "printTimeLeft": 48873,
    "printTimeLeftOrigin": "mixed-average"
  "state": "Printing"
This can easily be broken down into attributes via Home Assistant...
Is it just me or is this advertised-but-not-implemented in the plugin? Wouldn't it show up around line 129 if it were? See, there's no changeFeedRateSlowed() here.
I think it's because it should be changeFeedRateSlowPct.
You see what I'm saying, though? Their plugin advertises a new endpoint that they forgot to implement in this commit.
Oh yeah, I see now. It's being defined in the get_api function, but not in the on_api function. Just created issue on their repo.
Thanks a lot for chiming in. I'll liaise with the support guys from Mosaic to try to get them moving on this. Should really upgrade my request from focusing on Home Assistant to any Octoprint plugin really. The fact that they accepted merge requests by @gdombi shows they've got some kind of interest in supporting third party plugins. An Android compatible remote app with Palette support could be useful to me...
Anyways, I tried with a bunch of other endpoint and either got a 255 character error or it returned an unknown status.
sensor:
  - platform: rest
    method: POST
    payload: '{ "downloadPingHistory" }'
    headers:
      X-Api-Key: XXX
  - platform: rest
    method: POST
    headers:
      X-Api-Key: XXX
      dataType: json
  - platform: rest
    method: POST
    value_template: '{{ value_json.changeFeedRateSlowPct }}'
    headers:
      X-Api-Key: XXX
      dataType: json
  - platform: rest
    value_template: '{{ value_json.changeShowPingOnPrinter }}'
    json_attributes:
      - getPingHistory
      - changeFeedRateSlowed
      - changeFeedRateSlowPct
    headers:
      X-Api-Key: XXX
  - platform: rest
    method: POST
    payload: '{ "getPingHistory" }'
    headers:
      X-Api-Key: XXX
      dataType: json
 - platform: rest
   method: POST
   headers:
      X-Api-Key: XXX
      dataType: json
Wish I could see a list of json from the plugin... Using curl commands, I either get "forbidden"or "unknown". @jneilliii what command did you use to get the results from post #11?
It's at the top of that screenshot, using jquery"s ajax call. Because I was running it in browser's developer console logged in to octoprint, didn't have to worry about the api key.
Sorry to be a pain, total noob here... But, what command did you use for that request. Checked again in screenshot, but can't find the command used...
$.ajax({
                url: API_BASEURL + "plugin/palette2",
                type: "POST",
                dataType: "json",
                data: JSON.stringify({
                    command: "getPingHistory"
                contentType: "application/json; charset=UTF-8"
            }).done(function(data){console.log(data)});
Fair enough. Cheers for that. Noob indeed, but trying. I'll look into it when back home... I'll try to contact @gdombi to see, we can get some input. Looked at the github for OctoPod, but no luck: https://github.com/gdombiak/OctoPod
OK, got it. I can see the pings as such:
{readyState: 1, getResponseHeader: ƒ, getAllResponseHeaders: ƒ, setRequestHeader: ƒ, overrideMimeType: ƒ, …}
readyState: 4
getResponseHeader: Ć’ ( key )
getAllResponseHeaders: Ć’ ()
setRequestHeader: Ć’ ( name, value )
overrideMimeType: Ć’ ( type )
statusCode: Ć’ ( map )
abort: Ć’ ( statusText )
state: Ć’ ()
always: Ć’ ()
catch: Ć’ ( fn )
pipe: Ć’ ( /* fnDone, fnFail, fnProgress */ )
then: Ć’ ( onFulfilled, onRejected, onProgress )
promise: Ć’ ( obj )
progress: Ć’ ()
done: Ć’ ()
fail: Ć’ ()
responseText: "{↵  "data": [↵    {↵      "number": 1, ↵      "per"
responseJSON:
data: Array(237)
[0 … 99]
0:
number: 1
percent: 96.74
__proto__: Object
1: {number: 2, percent: 99.04}
2: {number: 3, percent: 100.17}
3: {number: 4, percent: 99.41}
4: {number: 5, percent: 100.04}
5: {number: 6, percent: 100.84}
6: {number: 7, percent: 101.04}
7: {number: 8, percent: 100.38}
8: {number: 9, percent: 100.06}
9: {number: 10, percent: 100.13}
10: {number: 11, percent: 100.17}
11: {number: 12, percent: 100.37}
12: {number: 13, percent: 101.03}
13: {number: 14, percent: 100.97}
14: {number: 15, percent: 100.54}
15: {number: 16, percent: 100.38}
16: {number: 17, percent: 100.33}
17: {number: 18, percent: 100.51}
18: {number: 19, percent: 100.89}
19: {number: 20, percent: 101.27}
20: {number: 21, percent: 101.18}
21: {number: 22, percent: 101}
22: {number: 23, percent: 101.31}
23: {number: 24, percent: 101.48}
24: {number: 25, percent: 100.97}
25: {number: 26, percent: 100.96}
26: {number: 27, percent: 101.48}
27: {number: 28, percent: 101.57}
28: {number: 29, percent: 101.35}
29: {number: 30, percent: 101.36}
30: {number: 31, percent: 101.28}
31: {number: 32, percent: 101.24}
32: {number: 33, percent: 101.08}
33: {number: 34, percent: 101.25}
34: {number: 35, percent: 101.34}
35: {number: 36, percent: 101.14}
36: {number: 37, percent: 101.24}
37: {number: 38, percent: 101.24}
38: {number: 39, percent: 101.01}
39: {number: 40, percent: 101.1}
40: {number: 41, percent: 101.59}
41: {number: 42, percent: 101.8}
42: {number: 43, percent: 102.15}
43: {number: 44, percent: 101.9}
44: {number: 45, percent: 101.61}
45: {number: 46, percent: 101.51}
46: {number: 47, percent: 101.08}
47: {number: 48, percent: 101.04}
48: {number: 49, percent: 101.24}
49: {number: 50, percent: 101.06}
50: {number: 51, percent: 101.03}
51: {number: 52, percent: 101.15}
52: {number: 53, percent: 100.86}
53: {number: 54, percent: 100.99}
54: {number: 55, percent: 101.18}
55: {number: 56, percent: 101.74}
56: {number: 57, percent: 102.36}
57: {number: 58, percent: 102.24}
58: {number: 59, percent: 102.19}
59: {number: 60, percent: 102.04}
60: {number: 61, percent: 101.64}
61: {number: 62, percent: 101.05}
62: {number: 63, percent: 100.79}
63: {number: 64, percent: 100.53}
64: {number: 65, percent: 100.96}
65: {number: 66, percent: 100.92}
66: {number: 67, percent: 100.5}
67: {number: 68, percent: 101.14}
68: {number: 69, percent: 101.24}
69: {number: 70, percent: 100.94}
70: {number: 71, percent: 100.87}
71: {number: 72, percent: 101.23}
72: {number: 73, percent: 101.24}
73: {number: 74, percent: 100.98}
74: {number: 75, percent: 101.32}
75: {number: 76, percent: 101.29}
76: {number: 77, percent: 100.89}
77: {number: 78, percent: 100.92}
78: {number: 79, percent: 101.22}
79: {number: 80, percent: 101.28}
80: {number: 81, percent: 101.02}
81: {number: 82, percent: 101.33}
82: {number: 83, percent: 101.34}
83: {number: 84, percent: 101.1}
84: {number: 85, percent: 101.05}
85: {number: 86, percent: 101.25}
86: {number: 87, percent: 101.35}
87: {number: 88, percent: 101.03}
88: {number: 89, percent: 101.15}
89: {number: 90, percent: 101.21}
90: {number: 91, percent: 101}
91: {number: 92, percent: 101.05}
92: {number: 93, percent: 101.39}
93: {number: 94, percent: 101.39}
94: {number: 95, percent: 101.05}
95: {number: 96, percent: 101.27}
96: {number: 97, percent: 101.44}
97: {number: 98, percent: 101.07}
98: {number: 99, percent: 101.04}
99: {number: 100, percent: 101.3}
[100 … 199]
100: {number: 101, percent: 101.26}
101: {number: 102, percent: 101}
102: {number: 103, percent: 101.31}
103: {number: 104, percent: 101.42}
104: {number: 105, percent: 101.07}
105: {number: 106, percent: 101.08}
106: {number: 107, percent: 101.26}
107: {number: 108, percent: 101.22}
108: {number: 109, percent: 100.84}
109: {number: 110, percent: 101.2}
110: {number: 111, percent: 101.41}
111: {number: 112, percent: 101.13}
112: {number: 113, percent: 101.07}
113: {number: 114, percent: 101.19}
114: {number: 115, percent: 101.27}
115: {number: 116, percent: 100.77}
116: {number: 117, percent: 101.08}
117: {number: 118, percent: 101.41}
118: {number: 119, percent: 101.03}
119: {number: 120, percent: 100.9}
120: {number: 121, percent: 101.18}
121: {number: 122, percent: 101.33}
122: {number: 123, percent: 100.82}
123: {number: 124, percent: 101.15}
124: {number: 125, percent: 101.18}
125: {number: 126, percent: 100.83}
126: {number: 127, percent: 101.08}
127: {number: 128, percent: 101.19}
128: {number: 129, percent: 101.1}
129: {number: 130, percent: 100.76}
130: {number: 131, percent: 101.12}
131: {number: 132, percent: 101.19}
132: {number: 133, percent: 100.89}
133: {number: 134, percent: 100.88}
134: {number: 135, percent: 101.18}
135: {number: 136, percent: 101.25}
136: {number: 137, percent: 100.9}
137: {number: 138, percent: 101.22}
138: {number: 139, percent: 101.22}
139: {number: 140, percent: 100.86}
140: {number: 141, percent: 100.88}
141: {number: 142, percent: 101.15}
142: {number: 143, percent: 101.1}
143: {number: 144, percent: 100.63}
144: {number: 145, percent: 101.09}
145: {number: 146, percent: 101.23}
146: {number: 147, percent: 100.83}
147: {number: 148, percent: 101.08}
148: {number: 149, percent: 101.08}
149: {number: 150, percent: 101.08}
150: {number: 151, percent: 100.85}
151: {number: 152, percent: 101.19}
152: {number: 153, percent: 101.32}
153: {number: 154, percent: 100.8}
154: {number: 155, percent: 101.01}
155: {number: 156, percent: 101.34}
156: {number: 157, percent: 101.19}
157: {number: 158, percent: 100.86}
158: {number: 159, percent: 101.29}
159: {number: 160, percent: 101.15}
160: {number: 161, percent: 100.8}
161: {number: 162, percent: 101.23}
162: {number: 163, percent: 101.08}
163: {number: 164, percent: 100.95}
164: {number: 165, percent: 100.86}
165: {number: 166, percent: 101.06}
166: {number: 167, percent: 101.27}
167: {number: 168, percent: 100.9}
168: {number: 169, percent: 101.1}
169: {number: 170, percent: 101.35}
170: {number: 171, percent: 101.18}
171: {number: 172, percent: 100.91}
172: {number: 173, percent: 101.41}
173: {number: 174, percent: 101.29}
174: {number: 175, percent: 100.86}
175: {number: 176, percent: 101.19}
176: {number: 177, percent: 101.23}
177: {number: 178, percent: 101.14}
178: {number: 179, percent: 100.91}
179: {number: 180, percent: 101.05}
180: {number: 181, percent: 101.06}
181: {number: 182, percent: 100.92}
182: {number: 183, percent: 101.04}
183: {number: 184, percent: 100.91}
184: {number: 185, percent: 101.03}
185: {number: 186, percent: 100.99}
186: {number: 187, percent: 101.14}
187: {number: 188, percent: 101.03}
188: {number: 189, percent: 100.69}
189: {number: 190, percent: 101}
190: {number: 191, percent: 100.93}
191: {number: 192, percent: 101.03}
192: {number: 193, percent: 100.91}
193: {number: 194, percent: 101.31}
194: {number: 195, percent: 101.38}
195: {number: 196, percent: 100.94}
196: {number: 197, percent: 101.62}
197: {number: 198, percent: 101.56}
198: {number: 199, percent: 101.33}
199: {number: 200, percent: 101.44}
[200 … 236]
200: {number: 201, percent: 101.1}
201: {number: 202, percent: 101.42}
202: {number: 203, percent: 101.7}
203: {number: 204, percent: 101.42}
204: {number: 205, percent: 101.42}
205: {number: 206, percent: 101.35}
206: {number: 207, percent: 101.57}
207: {number: 208, percent: 101.42}
208: {number: 209, percent: 101.57}
209: {number: 210, percent: 101.48}
210: {number: 211, percent: 101.13}
211: {number: 212, percent: 101.6}
212: {number: 213, percent: 101.44}
213: {number: 214, percent: 101.48}
214: {number: 215, percent: 101.61}
215: {number: 216, percent: 101.16}
216: {number: 217, percent: 101.37}
217: {number: 218, percent: 101.6}
218: {number: 219, percent: 101.49}
219: {number: 220, percent: 101.42}
220: {number: 221, percent: 101.21}
221: {number: 222, percent: 101.49}
222: {number: 223, percent: 101.93}
223: {number: 224, percent: 101.87}
224: {number: 225, percent: 101.64}
225: {number: 226, percent: 101.8}
226: {number: 227, percent: 101.82}
227: {number: 228, percent: 101.5}
228: {number: 229, percent: 101.88}
229: {number: 230, percent: 102}
230: {number: 231, percent: 101.25}
231: {number: 232, percent: 101.67}
232: {number: 233, percent: 102.11}
233: {number: 234, percent: 101.57}
234: {number: 235, percent: 101.64}
235: {number: 236, percent: 101.95}
236: {number: 237, percent: 101.62}
length: 237
@jneilliii: Do you know how we could push the last ping to the Mqtt plug-in on say a 30s interval?
downloadPingHistory also works:
$.ajax({
                type: "POST",
                dataType: "json",
                    command: "downloadPingHistory"
{data: {…}, response: "POST request (downloadPingHistory) successful", status: 200}
data:
data: "Solar_System_Scale_New↵↵PING            (%)↵===================↵Ping 1       96.74%↵Ping 2       99.04%↵Ping 3      100.17%↵Ping 4       99.41%↵Ping 5      100.04%↵Ping 6      100.84%↵Ping 7      101.04%↵Ping 8      100.38%↵Ping 9      100.06%↵Ping 10     100.13%↵Ping 11     100.17%↵Ping 12     100.37%↵Ping 13     101.03%↵Ping 14     100.97%↵Ping 15     100.54%↵Ping 16     100.38%↵Ping 17     100.33%↵Ping 18     100.51%↵Ping 19     100.89%↵Ping 20     101.27%↵Ping 21     101.18%↵Ping 22      101.0%↵Ping 23     101.31%↵Ping 24     101.48%↵Ping 25     100.97%↵Ping 26     100.96%↵Ping 27     101.48%↵Ping 28     101.57%↵Ping 29     101.35%↵Ping 30     101.36%↵Ping 31     101.28%↵Ping 32     101.24%↵Ping 33     101.08%↵Ping 34     101.25%↵Ping 35     101.34%↵Ping 36     101.14%↵Ping 37     101.24%↵Ping 38     101.24%↵Ping 39     101.01%↵Ping 40      101.1%↵Ping 41     101.59%↵Ping 42      101.8%↵Ping 43     102.15%↵Ping 44      101.9%↵Ping 45     101.61%↵Ping 46     101.51%↵Ping 47     101.08%↵Ping 48     101.04%↵Ping 49     101.24%↵Ping 50     101.06%↵Ping 51     101.03%↵Ping 52     101.15%↵Ping 53     100.86%↵Ping 54     100.99%↵Ping 55     101.18%↵Ping 56     101.74%↵Ping 57     102.36%↵Ping 58     102.24%↵Ping 59     102.19%↵Ping 60     102.04%↵Ping 61     101.64%↵Ping 62     101.05%↵Ping 63     100.79%↵Ping 64     100.53%↵Ping 65     100.96%↵Ping 66     100.92%↵Ping 67      100.5%↵Ping 68     101.14%↵Ping 69     101.24%↵Ping 70     100.94%↵Ping 71     100.87%↵Ping 72     101.23%↵Ping 73     101.24%↵Ping 74     100.98%↵Ping 75     101.32%↵Ping 76     101.29%↵Ping 77     100.89%↵Ping 78     100.92%↵Ping 79     101.22%↵Ping 80     101.28%↵Ping 81     101.02%↵Ping 82     101.33%↵Ping 83     101.34%↵Ping 84      101.1%↵Ping 85     101.05%↵Ping 86     101.25%↵Ping 87     101.35%↵Ping 88     101.03%↵Ping 89     101.15%↵Ping 90     101.21%↵Ping 91      101.0%↵Ping 92     101.05%↵Ping 93     101.39%↵Ping 94     101.39%↵Ping 95     101.05%↵Ping 96     101.27%↵Ping 97     101.44%↵Ping 98     101.07%↵Ping 99     101.04%↵Ping 100     101.3%↵Ping 101    101.26%↵Ping 102     101.0%↵Ping 103    101.31%↵Ping 104    101.42%↵Ping 105    101.07%↵Ping 106    101.08%↵Ping 107    101.26%↵Ping 108    101.22%↵Ping 109    100.84%↵Ping 110     101.2%↵Ping 111    101.41%↵Ping 112    101.13%↵Ping 113    101.07%↵Ping 114    101.19%↵Ping 115    101.27%↵Ping 116    100.77%↵Ping 117    101.08%↵Ping 118    101.41%↵Ping 119    101.03%↵Ping 120     100.9%↵Ping 121    101.18%↵Ping 122    101.33%↵Ping 123    100.82%↵Ping 124    101.15%↵Ping 125    101.18%↵Ping 126    100.83%↵Ping 127    101.08%↵Ping 128    101.19%↵Ping 129     101.1%↵Ping 130    100.76%↵Ping 131    101.12%↵Ping 132    101.19%↵Ping 133    100.89%↵Ping 134    100.88%↵Ping 135    101.18%↵Ping 136    101.25%↵Ping 137     100.9%↵Ping 138    101.22%↵Ping 139    101.22%↵Ping 140    100.86%↵Ping 141    100.88%↵Ping 142    101.15%↵Ping 143     101.1%↵Ping 144    100.63%↵Ping 145    101.09%↵Ping 146    101.23%↵Ping 147    100.83%↵Ping 148    101.08%↵Ping 149    101.08%↵Ping 150    101.08%↵Ping 151    100.85%↵Ping 152    101.19%↵Ping 153    101.32%↵Ping 154     100.8%↵Ping 155    101.01%↵Ping 156    101.34%↵Ping 157    101.19%↵Ping 158    100.86%↵Ping 159    101.29%↵Ping 160    101.15%↵Ping 161     100.8%↵Ping 162    101.23%↵Ping 163    101.08%↵Ping 164    100.95%↵Ping 165    100.86%↵Ping 166    101.06%↵Ping 167    101.27%↵Ping 168     100.9%↵Ping 169     101.1%↵Ping 170    101.35%↵Ping 171    101.18%↵Ping 172    100.91%↵Ping 173    101.41%↵Ping 174    101.29%↵Ping 175    100.86%↵Ping 176    101.19%↵Ping 177    101.23%↵Ping 178    101.14%↵Ping 179    100.91%↵Ping 180    101.05%↵Ping 181    101.06%↵Ping 182    100.92%↵Ping 183    101.04%↵Ping 184    100.91%↵Ping 185    101.03%↵Ping 186    100.99%↵Ping 187    101.14%↵Ping 188    101.03%↵Ping 189    100.69%↵Ping 190     101.0%↵Ping 191    100.93%↵Ping 192    101.03%↵Ping 193    100.91%↵Ping 194    101.31%↵Ping 195    101.38%↵Ping 196    100.94%↵Ping 197    101.62%↵Ping 198    101.56%↵Ping 199    101.33%↵Ping 200    101.44%↵Ping 201     101.1%↵Ping 202    101.42%↵Ping 203     101.7%↵Ping 204    101.42%↵Ping 205    101.42%↵Ping 206    101.35%↵Ping 207    101.57%↵Ping 208    101.42%↵Ping 209    101.57%↵Ping 210    101.48%↵Ping 211    101.13%↵Ping 212     101.6%↵Ping 213    101.44%↵Ping 214    101.48%↵Ping 215    101.61%↵Ping 216    101.16%↵Ping 217    101.37%↵Ping 218     101.6%↵Ping 219    101.49%↵Ping 220    101.42%↵Ping 221    101.21%↵Ping 222    101.49%↵Ping 223    101.93%↵Ping 224    101.87%↵Ping 225    101.64%↵Ping 226     101.8%↵Ping 227    101.82%↵Ping 228     101.5%↵Ping 229    101.88%↵Ping 230     102.0%↵Ping 231    101.25%↵Ping 232    101.67%↵Ping 233    102.11%↵Ping 234    101.57%↵Ping 235    101.64%↵Ping 236    101.95%↵Ping 237    101.62%↵Ping 238    101.63%↵Ping 239    101.93%↵Ping 240    101.46%↵Ping 241    101.18%↵"
filename: "Solar_System_Scale_New.txt"
__proto__: Object
status: 200
Look at the code of my mqtt-publish plugin. It has all the necessary info for using the mqtt plugin's helpers and sending the data. You'd just have to wrap your api call/post-processing (get last ping)/mqtt publish in a repeated timer.
Cheers. Will look into it. Giving myself a headache prodding around trying to get other commands working unsuccessfully...
OK, this solution is node ideal for me. I'm going to try to push for more API calls. Opened a Feature Request on GitLab here: https://gitlab.com/mosaic-mfg/palette-2-plugin/issues/8
My coding abilisties do not allow for me to make the commits without assistance!
The wonderful @gdombi made himself available and sorted this out here: https://gitlab.com/mosaic-mfg/palette-2-plugin/-/merge_requests/94
@Monkey_House
Happy New Year 2021
I hope you wouldn't mind me asking how far did you get with that Palette sensor for Home Assistant?
I checked the above conversation and replicated your sensor snippets with no result.
