Https using Lets Encrypt
I'm using this guide for my Domoticz installation.
I want to use the same on my octoprint installation.
Could someone point me to where I could add the cert config line ?
TIA
Daniel
That is part of the steps in my ssl tutorial.
Hopefully that will point you in the right direction. The haproxy.cfg has some pre-configured ssl settings for the snakeoil cert in there if I'm remembering correctly..
Found this guide
If you wish you could update your guide to get a cert from that guide. Worked great.
I have read it here but do not know if it works.
Solved it by letting my router act as frontend for the SSL traffic.
