I run Octoprint version 1.6.1 on Octopi 0.17.0 on a Raspberry Pi 4 Bvs.1.2. so far it did work well and being rather busy and away from the printer, I missed a number of updates. I tried to do so now, but failed.
This is the error message I got:
ERROR: Command errored out with exit status1: /home/pi/oprint/bin/python2/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py get_requires_for_build_wheel /tmp/tmpk4Rsx4 Check the logs for full command output.
Getting requirements to build wheel: finished with status error
Die Aktualisierung wurde nicht erfolgreich abgeschlossen. Bitte konsultiere octoprint.log und plugin_softwareupdate_console.log für Details.
I disabled 3rd party plugins, I looked for answers in the forum, I tried the solution suggested for update from 1.6.1 to 1.7.3
Yes
I restarted in safe mode but ended up with the same result
octoprint-systeminfo-20241222120644.zip (45.8 KB)
octoprint-logs.zip (104.9 KB)
I assume I can always start allover with a new image on the SD card, but was hoping there is a way to save me the time doing that.
Thank you for all the effort and support.
Michael
