Is there anything that will let me do remote shutdown of Octopi?
#1
(topic withdrawn by author, will be automatically deleted in 24 hours unless flagged)
#2
On the menu bar at the top you can reboot octoprint, reboot the system and shutdown the system
#3
Thanks for the reply!
I knew that, though -- I was meaning how to do it without being at a computer (using a hardware button connected to Raspberry Pi, or from a smart phone. Octoprint Anywhere doesn't support shutdown I requested it, but it was not added). I want to do shutdown without running up and down stairs from the computer to do the software shutdown and then to the printer for a power disconnect to avoid SDCard corruption.
( deleted the question after realizing that I'd asked it before)
#4
You can load the web interface on your smartphone and use the same menu option to shutdown octoprint or the pi.
#5
Thanks, yes that works (at least it does now with my phone that has a larger screen!).
#6
Hi @bwaslo!
You also can add the Touch UI plugin to make things more comfortable on a smart phone.
I use Printoid on my smart phone which allows me to shutdown from anywhere
