Has anyone here used 2to3? I haven't tried it out yet, but it looks interesting. Might be a good place to start.
I have used 2to3. Since I'm fairly leery about other people's transpilers I tend to go the route of:
- clone my code into another working directory
- run 2to3 there
- use Visual Studio Code's
Source Controltab to review the before/after changes that made - go to school on their changes
Took me way too long to get back to my own topic thanks to the new RC - sorry for that
You can actually skip a ton of these steps - or at least it worked fine on my end to do that... virtualenv has an argument --python with which you can specify the Python interpreter with which to create the venv. So it boils down to installing both 2.7 and 3.7 somewhere and then telling virtualenv which interpreter to use:
virtualenv --python=C:/Python27/python.exe venv27
virtualenv --python=C:/Python37/python.exe venv37
Then just activate whichever one you need, or - that's how I do it - configure both interpreters in your IDE and then switch there. The only bad thing about the latter is that at least my (slightly outdated) version of PyCharm always needs an extra minute to get back on track after that, and I have to make sure to close all active run/debug panels relating to the old Python environment or it doesn't properly switch
Does that support 2 and 3 concurrently? I always took it to be more a case of "once that's run the code won't run under Py2 anymore", which at least for now would be counter productive.
What I've made good use of is this cheat sheet by the Python-Future project:
https://python-future.org/compatible_idioms.html
And in general it seems to be a good idea to turn on Py3 behaviour as far as possible in your source files through various from __future__ imports. E.g. (from OctoPrint's code base):
# -*- coding: utf-8 -*-
from __future__ import absolute_import, division, print_function, unicode_literals
I also have a post-it note attached to my main screen for more than a year now that currently says
except Exception:to_bytes&to_unicodeio.openlist(<generator>)
mapfilter- ...
__metaclass__
Explanation follows
except Exception:
Instead of just except: for broad catch-all blocks. Not Python 3 specific, but something we switched to in the code base with the Py3 changes.
to_bytes&to_unicode
Two helper methods built into OctoPrint (octoprint.util package) that should hopefully make it easier to ensure the expected data type. Will keep their hands off of anything that's already in the correct type.
io.open
Instead of open if I remember correctly, though I cannot for the life of me right now remember what exactly was special about that. Pretty sure it had something to do with encoding though (because that's the worst about this whole migration).
list(<generator>)
This is what @OutsourcedGuru already mentioned, a ton of the functional programming kinda methods in Python 3 are now returning generators instead of ready data, so if you want to do stuff with that later where it needs to be a list you'll need to convert yourself. Has kicked me in the teeth a couple of times now, one of the fixes that went into RC6 was actually another one of these.
__metaclass__
Meta classes work differently in Py2 (__metaclass__ field) and Py3 (metaclass= argument in the class declaration). In an incompatible way of course. So yeah, this works best:
from future.utils import with_metaclass
class Foo(with_metaclass(FooType, BarType)):
pass
And then there's this result of searching for except ImportError: in OctoPrint's code base:
Queuevsqueue:try: # noinspection PyCompatibility import queue # Py3 except ImportError: # noinspection PyCompatibility import Queue as queue # Py2 -
Chainmap:try: # noinspection PyCompatibility from collections.abc import ChainMap # Py3, built-in except ImportError: # noinspection PyCompatibility from chainmap import Chainmap # Py2, external dependency -
KeysView:try: # noinspection PyCompatibility from collections.abc import KeysView # Py3 except ImportError: # noinspection PyCompatibility from collections import KeysView # Py2 -
scandir&walk:try: # noinspection PyCompatibility from os import scandir, walk # Py3, built-in except ImportError: # noinspection PyCompatibility from scandir import scandir, walk # Py2, external dependency -
HTMLParsertry: # noinspection PyCompatibility from html.parser import HTMLParser # Py3 except ImportError: # noinspection PyCompatibility from HTMLParser import HTMLParser # Py2 -
HTTPResponsetry: # noinspection PyCompatibility from http.client import HTTPResponse # Py3 except ImportError: # noinspection PyCompatibility from httplib import HTTPResponse # Py2 -
HTTPServer&BaseHTTPRequestHandler:try: # noinspection PyCompatibility from http.server import HTTPServer, BaseHTTPRequestHandler # Py3 except ImportError: # noinspection PyCompatibility from BaseHTTPServer import HTTPServer, BaseHTTPRequestHandler # Py2 -
urlencodetry: # noinspection PyCompatibility from urllib.parse import urlencode # Py3 except ImportError: # noinspection PyCompatibility from urllib import urlencode # Py2 -
urllib.unquotevsurllib.parse.unquote(same goes forurlencode):try: # noinspection PyCompatibility from urllib.parse import unquote # Py3 except: # noinspection PyCompatibility from urllib import unquote # Py2 -
urlparse
try: # noinspection PyCompatibility from urllib import parse as urlparse # Py3 except ImportError: # noinspection PyCompatibility import urlparse # Py2 -
collections.Iterableand Python 3.8 (!):try: from collections import Iterable except ImportError: # Python >= 3.8 from collections.abc import Iterable
Now ain't that fun?
Wow, look at you. I'm reminded of the ski instructor from South Park. I should write a CLI called ski_instructor which takes a Py2 file as an argument, looks for those and then reports back warnings in his transcript.
I need to study this thread more closely but with only one 3D printer, I need to understand how to switch back and forth between Py2 and Py3 as some of the plugins I have installed are "required" for successful printing but I need a Py3 environment to migrate, test, and debug the plugin(s) I have written.
Another thing I think would be desirable is an enhancement to the Plugin Manager that can display the Py2/Py3 status of each plugin. This would make it easier for me to determine when my "required" subset of plugins will work in the Py3 environment (or if I need to "adopt" some to move things along).
The technique I'd use would be to iteratively visit the plugin's repository and look for the tell-tale signature by searching their entire repository for: __plugin_pythoncompat__ and look for...
__plugin_pythoncompat__ = ">=2.7,<4"
Even better:
https://plugins.octoprint.org/plugins.json
Look for compatibility -> python.
Py3
- https://github.com/jneilliii/Octoprint-STLViewer
- https://github.com/mtowara/OctoPrint-Gcodebar
- https://github.com/jneilliii/OctoPrint-M117NavBar
- https://github.com/jneilliii/OctoPrint-M117PopUp
- https://github.com/kantlivelong/OctoPrint-PSUControl
- https://github.com/google/OctoPrint-LEDStripControl
- https://github.com/google/OctoPrint-TemperatureFailsafe
- https://github.com/jneilliii/OctoPrint-BLTouch
- https://github.com/jneilliii/OctoPrint-CustomBackground
- https://github.com/jneilliii/OctoPrint-TPLinkSmartplug
- https://github.com/google/OctoPrint-HeaterTimeout
- https://github.com/jneilliii/OctoPrint-Tasmota
- https://github.com/cesarvandevelde/OctoPrint-M73Progress
- https://github.com/jneilliii/OctoPrint-FloatingNavbar
- https://github.com/jneilliii/OctoPrint-MQTTPublish
- https://github.com/jneilliii/OctoPrint-TasmotaMQTT
- https://github.com/jneilliii/OctoPrint-M117SpeechSynthesis
- https://github.com/jneilliii/OctoPrint-TabOrder
- https://github.com/OctoPrint/OctoPrint-MalyanConnectionFix
- https://github.com/jneilliii/OctoPrint-BedLevelVisualizer
- https://github.com/jneilliii/OctoPrint-ipOnConnect
- https://github.com/jneilliii/OctoPrint-SideBarTempGraph
- https://github.com/jneilliii/OctoPrint-Domoticz
- https://github.com/eyal0/OctoPrint-PrintTimeGenius
- https://github.com/jneilliii/OctoPrint-StatefulSidebar
- https://github.com/jneilliii/OctoPrint-WemoSwitch
- https://framagit.org/razer/Octoprint_ABL_Expert
- https://github.com/jneilliii/OctoPrint-ActiveFiltersExtended
- https://github.com/jneilliii/OctoPrint-DragonOrder
- https://github.com/jneilliii/OctoPrint-MyMiniFactory
- https://github.com/gdombiak/OctoPrint-OctoPod
- https://github.com/agrif/OctoPrint-InfluxDB
- https://github.com/jneilliii/OctoPrint-UltimakerFormatPackage
- https://github.com/scottrini/OctoPrint-PrusaLevelingGuide
- https://github.com/entrippy/OctoPrint-OctoHue
- https://github.com/pwnbus/OctoPrint-Progress-Title
- https://github.com/jneilliii/OctoPrint-TerminalCommandsExtended
Of 190 plugins in the .json, 38 are compatible with Python3.
I just wrote something. If you have NodeJS installed on your workstation...
cd sites # wherever you store projects
mkdir testplugins
cd testplugins
npm init
npm install
npm install --save octo-client
# edit node_modules/octo-client/config.js with your API key!
touch index.js
# --- Contents follow
const https = require('https');
const OctoPrint = require('octo-client');
String.prototype.isNotInList = function() {
let value = this.valueOf();
for (let i = 0, l = arguments[0].length; i < l; i += 1) {
if (arguments[0][i] === value) return false;
return true;
function fetchPluginJSON(callback) {
var url = 'https://plugins.octoprint.org/plugins.json'
// id and compatibility.python
https.get(url, function(resp) {
let data = '';
resp.on('data', (chunk) => {
data += chunk;
resp.on('end', function() {
callback(true, data);
}).on("error", function(err) {
callback(false, err.message);
OctoPrint.settings(function(opResponse){
var listBundled = [
'action_command_prompt',
'announcements',
'discovery',
'errortracking',
'pi_support',
'pluginmanager',
'softwareupdate',
'tracking'
var jsonUrlPlugins = {}
fetchPluginJSON(function(wasSuccessful, urlJsonDataOrError) {
if (wasSuccessful) {
jsonUrlPlugins = urlJsonDataOrError;
jsonOpList = opResponse.plugins;
var listOpNames = Object.keys(jsonOpList);
var installed3rdPartyPlugins = listOpNames.filter(function(name) {
return name.isNotInList(listBundled);
var specificItem = {};
var version = '';
installed3rdPartyPlugins.forEach(function(name) {
specificItem = {};
version = '';
specificItem = JSON.parse(jsonUrlPlugins).filter(function(entry) {return entry.id == name;});
if (specificItem.length == 0) {
console.log(name + ': (?)' + ' '.repeat(30 - name.length) + ' not in public list (unknown status)');
} else {
version = specificItem[0].compatibility.python;
if (version.indexOf('<4') > -1) {
console.log(name + ': (YES)' + ' '.repeat(28 - name.length) + ' Python 3 compatible [' + version + ']');
} else {
console.log(name + ': (NO)' + ' '.repeat(29 - name.length) + ' not Python 3 compatible [' + version + ']');
} else {
console.log('Plugin lookup error: ' + urlJsonDataOrError);
# --- End of index.js contents
node . # Run the report
unpublishedplugin: (?) not in public list (unknown status)
stlviewer: (YES) Python 3 compatible [>=2.7,<4]
screensquish: (NO) not Python 3 compatible [>=2.7,<3]
A little bit more context about your program:
- loading of https://plugins.octoprint.org/plugins.json
- loads the list of your "local" installation
- compares each list and output the result
DisplayLayerProgress: (NO) not Python 3 compatible [>=2.7,<3]
PrintJobHistory: (?) not in public list (unknown status)
HINT: You need to enter your OctoPrint-Connection-Settings to node_modules/octo-client/config.js before executing.
My DLP-Plugin is listed as not compatible, this is not true!
Reason: I didn't know/realised that, beside
- this statement
__plugin_pythoncompat__ = ">=2.7,<4", - syntactically python3-sugar,
- I also need to add this info into the plugin-description for the plugin-respository:
compatibility:
python: ">=2.7,<4"
Btw. beside your already mentioned python 3 - statements on top of this thread, there is one thing missing myDict.hasKey(something) https://docs.python.org/3.1/whatsnew/3.0.html#builtins
I created a wiki-page about that stuff (at the moment it doesn't include much content): https://github.com/OllisGit/OctoPrint-KnowledgeBase/wiki/PluginPython23
@FormerLurker I added a short section about your gcode_parser.py, because I use this in my DryRun-Plugin..maybe it helps.
Noted in the instructions, thanks.
And yeah, I think OctoPrint 1.4 under a Py3 environment would need the plugin repository to have that compatibility information for others to install it.
Yeah, without the compatibility setting in the plugin repository, the plugin manager won't show the plugins listed to install under a Py3 environment. They get filtered out.
Sorry about that, working on a lengthy write up as we speak to make all this clearer.
Needed to do it that way, otherwise the only way to have done this would have been either
- Offer incompatible plugins to the user for installation and have them run into errors during install - really bad user experience.
- Try to fetch that information from the net from every single OctoPrint instance on every single repository listing - completely unfeasible.
So just like the other compatibility information, it lives in there now. And I had to do the additional flag in the code base because otherwise stuff might explode on plugin load thanks to syntactic changes.
I've got a first version of a migration guide online here:
https://docs.octoprint.org/en/staging-maintenance/plugins/python3_migration.html
In the end I decided against a blog post and rather made this part of the documentation. Let me know what you think please!
I'm thinking about releasing 1.4.0 this Wednesday (March 4th), if things continue to look as well as they do right now. I want the migration guide to go out along with it, so the current timeline means I'll be able to incorporate any changes that come out of this thread until tomorrow ~18:00 CET
Sweet. I wrote yesterday that I thought you'd release this week.
Don't forget /etc/default/octoprint, btw.
What about that? That's an OctoPi detail, not generic OctoPrint.
Hi @foosel,
IMHO the approach to include this important topic to the official documentation is the right way!
Now it is also possible to raise Pull-Request to improve the content (e.g typos or setting up PyCharm with two envs ;-)).
I like the idea that you include the setup of the two environments and also the checklist at the end.
But from my point of view one important thing is missing:
- OctoPrint API-Breaking changes (maybe not the right words)
From a plugin developer perspective, of course I need to know/learn the differences between Pyt2/3, but I also need to know which OctoPrint-API/Hook/Payload behaves differently.
Currently I only know the OctoPrint LineProcessorStream-Hook, but maybe there is more.
My suggestion is to put such findings also to this document in a separate section.
What do you think?
Olli
BTW. I like the release date!!!
I would say that most of us begin with an OctoPi-imaged rig and modify it for Py3. So when you sudo service octoprint restart I'm guessing that it uses the indicated file for that configuration information and that points to the old ~/oprint location rather than the one you've described in the newly-created documentation.
The thing is, I made it a conscious effort not to have any breaking changes on the API. What you are referring to here isn't a breaking change in OctoPrint, it's a breaking change in Python 3 that affects a helper class provided by OctoPrint as that inherits from a core Python class. I'll make a mention of it in the bytes vs string section though to give it some more visibility. It's also the only thing that I'm aware of at present.
edit Added:
I sincerely hope that that's not how most plugin developers start given that the tutorial explicitly walks people through setting up a proper local development environment. Developing directly on a Pi is just painful.
I also make it a point to start OctoPrint manually from shell in the migration guide, in the corresponding venv, via the octoprint executable. I'd rather not want to confuse people and start with OctoPi details there, especially not since the guide isn't about how to migrate your OctoPi image to using Python 3, but rather how to migrate your OctoPrint plugins to Python 3... I'll think about adding a footnote though.
edit Added, and not as a footnote:
Things I had todo for TouchUI.
First off; migration docs where helpfull!
Second, this is what I had to fix:
- basestring no longer supported, update crossdomain decorator (/w backwards compatibly) with the following
try:
basestring
except NameError:
basestring = str
- Hashing now requires encoding:
Old:hashlib.md5(contentFile.read())
New:hashlib.md5(contentFile.read().encode('utf-8'))
That was it for me.
@foosel, I just tried to follow your Migrating to Python 3 and I'm still a little confused...
I have a working OctoPi 0.17.0 / OctoPrint 1.4.0 with installed plugins. I believe this "virtual environment is "~/oprint". I have created a venv3, activated it, and installed OctoPrint.
Maybe I'm too old to read between the lines but the next step is, "create an editable install of your plugin, start the server and start testing" and for me, that leaves out a step (or more) before like "shutdown your current OctoPrint environment" and maybe a step after "to return to your original OctoPrint environment".
I think maybe the second note (If you want to migrate your existing OctoPrint install) might be more relevant to what I am trying to accomplish, have both environments available and switch between them as needed. Adding the "switch" commands would be very useful, IMO.
