New plugin: MQTT for PSUControl
Alright. It's uploaded. Should be able to pull the correct value from the incoming data now. But you have to put the correct response messages into the settings. All the {"..":".."} stuff needs to be there and correct (case sensitive in some parts, will improve that later probably).
I think the statetopic was correctly set to ../OctoPower from what I saw in the logs.
Looking good. Status is read fine even when operating the socket from elsewhere. Nice work.
Thank you! I will go towards releasing it officially then. PS: don't forget disabling the debug logging.
