Sorry, my mistake, could you change the -a flag to --all ?
pi@octopi:~ $ v4l2-ctl --all -d /dev/v4l/by-id/usb-046d_C922_Pro_Stream_Webcam_BDFE0F4F-video-index0
Driver Info:
Driver name : uvcvideo
Card type : C922 Pro Stream Webcam
Bus info : usb-0000:01:00.0-1.1
Driver version : 5.10.52
Capabilities : 0x84a00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Model : C922 Pro Stream Webcam
Serial : BDFE0F4F
Media version : 5.10.52
Hardware revision: 0x00000016 (22)
Interface Info:
Type : V4L Video
Entity Info:
Name : C922 Pro Stream Webcam
Function : V4L2 I/O
Flags : default
Pad 0x01000007 : 0: Sink
Link 0x0200001f: from remote pad 0x100000a of entity 'Processing 3': Data, Enabled, Immutable
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
Width/Height : 640/480
Pixel Format : 'YUYV' (YUYV 4:2:2)
Field : None
Bytes per Line : 1280
Size Image : 614400
Colorspace : sRGB
Transfer Function : Rec. 709
YCbCr/HSV Encoding: ITU-R 601
Quantization : Default (maps to Limited Range)
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 640, Height 480
Default : Left 0, Top 0, Width 640, Height 480
Pixel Aspect: 1/1
Selection: crop_default, Left 0, Top 0, Width 640, Height 480, Flags:
Selection: crop_bounds, Left 0, Top 0, Width 640, Height 480, Flags:
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 10.000 (10/1)
Read buffers : 0
brightness 0x00980900 (int) : min=0 max=255 step=1 default=128 value=128
contrast 0x00980901 (int) : min=0 max=255 step=1 default=128 value=128
saturation 0x00980902 (int) : min=0 max=255 step=1 default=128 value=128
white_balance_temperature_auto 0x0098090c (bool) : default=1 value=1
gain 0x00980913 (int) : min=0 max=255 step=1 default=0 value=0
power_line_frequency 0x00980918 (menu) : min=0 max=2 default=2 value=2
white_balance_temperature 0x0098091a (int) : min=2000 max=6500 step=1 default=4000 value=4000 flags=inactive
sharpness 0x0098091b (int) : min=0 max=255 step=1 default=128 value=128
backlight_compensation 0x0098091c (int) : min=0 max=1 step=1 default=0 value=0
exposure_auto 0x009a0901 (menu) : min=0 max=3 default=3 value=3
exposure_absolute 0x009a0902 (int) : min=3 max=2047 step=1 default=250 value=250 flags=inactive
exposure_auto_priority 0x009a0903 (bool) : default=0 value=1
pan_absolute 0x009a0908 (int) : min=-36000 max=36000 step=3600 default=0 value=0
tilt_absolute 0x009a0909 (int) : min=-36000 max=36000 step=3600 default=0 value=0
focus_absolute 0x009a090a (int) : min=0 max=250 step=5 default=0 value=0 flags=inactive
focus_auto 0x009a090c (bool) : default=1 value=1
zoom_absolute 0x009a090d (int) : min=100 max=500 step=1 default=100 value=100
pi@octopi:~ $ v4l2-ctl --all -d /dev/v4l/by-id/usb-046d_HD_Pro_Webcam_C920_A69AE6FF-video-index0
Driver Info:
Card type : HD Pro Webcam C920
Bus info : usb-0000:01:00.0-1.2
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Model : HD Pro Webcam C920
Serial : A69AE6FF
Hardware revision: 0x00000011 (17)
Interface Info:
Type : V4L Video
Entity Info:
Name : HD Pro Webcam C920
Function : V4L2 I/O
Flags : default
Priority: 2
Width/Height : 1920/1080
Pixel Format : 'MJPG' (Motion-JPEG)
Field : None
Bytes per Line : 0
Size Image : 4147200
Colorspace : sRGB
Quantization : Default (maps to Full Range)
Flags :
Bounds : Left 0, Top 0, Width 1920, Height 1080
Default : Left 0, Top 0, Width 1920, Height 1080
Pixel Aspect: 1/1
Selection: crop_default, Left 0, Top 0, Width 1920, Height 1080, Flags:
Selection: crop_bounds, Left 0, Top 0, Width 1920, Height 1080, Flags:
Frames per second: 15.000 (15/1)
Read buffers : 0
Ok, then the output of v4l2-ctl --list-formats -d /dev/v4l/by-id/usb-046d_C922_Pro_Stream_Webcam_BDFE0F4F-video-index0 please ?
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
[1]: 'MJPG' (Motion-JPEG, compressed)
btw I really appreciate your time and help you are providing me. i feel really bad that i cant figure this out on my own. lol
No worries, I know webcams can be a pain to set up. It would be better if I also provided the correct commands on the first try,
Could you please paste the output of v4l2-ctl --list-formats-ext -d /dev/v4l/by-id/usb-046d_C922_Pro_Stream_Webcam_BDFE0F4F-video-index0 ?
pi@octopi:~ $ v4l2-ctl --list-formats-ext -d /dev/v4l/by-id/usb-046d_C922_Pro_Stream_Webcam_BDFE0F4F-video-index0
Type: Video Capture
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1920x1080
Size: Discrete 2304x1296
Interval: Discrete 0.500s (2.000 fps)
Size: Discrete 2304x1536
Interval: Discrete 0.017s (60.000 fps)
OK, I was trying to figure out if you were perhaps using a resolution not supported by the webcam, but that doesn't seem to be the case.
Would you happen to know which of the webcams is running now, and which one isn't ?
right now the c922 is running and the c920 is not.
Ok, then could you please run v4l2-ctl -L -d /dev/v4l/by-id/usb-046d_HD_Pro_Webcam_C920_A69AE6FF-video-index0 and give the output here ?
pi@octopi:~ $ v4l2-ctl -L -d /dev/v4l/by-id/usb-046d_HD_Pro_Webcam_C920_A69AE6FF-video-index0
Failed to open /dev/v4l/by-id/usb-046d_HD_Pro_Webcam_C920_A69AE6FF-video-index0: Device or resource busy
interesting because it isn't busy running.
pi@octopi:~ $ v4l2-ctl -L -d /dev/v4l/by-id/usb-usb-046d_C922_Pro_Stream_Webcam_BDFE0F4F-video-index0
Cannot open device /dev/v4l/by-id/usb-usb-046d_C922_Pro_Stream_Webcam_BDFE0F4F-video-index0, exiting.
Interesting error, never encoutered that one...
What is the output of sudo lsof /dev/v4l/by-id/usb-046d_HD_Pro_Webcam_C920_A69AE6FF-video-index0 ? If it is empty, could you try sudo fuser /dev/v4l/by-id/usb-046d_HD_Pro_Webcam_C920_A69AE6FF-video-index0 ? The fuser command should be provided by the psmisc package.
pi@octopi:~ $ sudo lsof /dev/v4l/by-id/usb-046d_HD_Pro_Webcam_C920_A69AE6FF-video-index0
sudo: lsof: command not found
pi@octopi:~ $ sudo fuser /dev/v4l/by-id/usb-046d_HD_Pro_Webcam_C920_A69AE6FF-video-index0
pi@octopi:~ $
nothing happens for the fuser command
Could you install the lsof package to get the command ?
currently running a print through octoprint that should be done within 2 hours. if i install in now will it affect my current print status?
It shouldn't but if you feel more comfortable waiting for your print, there's no rush
ok ill probably just wait to be safe. after i run it just do a reboot and then "sudo fuser /dev/v4l/by-id/usb-046d_HD_Pro_Webcam_C920_A69AE6FF-video-index0" should work?
I'd rather you install the lsof package and then run the command. No need to reboot. The fuser command doesn't seem that helpful, lsof should be.
ok do i just type sudo get lsof?
sudo apt-get install lsof yes
downloaded and ran both commands neither do anything
