System here shows ABL Expert Plugin 0.5 installed, asks for update to 0.6 - when done, it appears that update failed, still showing 0.5, asking for 0.6 again. Whats wrong with that one ? Thanks
The author of the plugin should be contacted. I'd suggest opening an issue on the plugin's source repository. Follow the logs link which will help you collect the information the plugin author (or anyone) needs to help you.
Having the same issue with my ABL
It is a known issue. I have un-intalled ABL 0.5 and re-installed ABL, then being 0.6. Now all done. Suggest you do the same. I take it the developer has meanwhile amended the code in respect of tht process.
