looking to do this https://www.kodamaforums.com/phpBB3/viewtopic.php?t=2060# and I did some research on config.yaml on locations but nothing really on how to create it via octoprint.
Do I need to ssh and insert file via putty? having the z offset on octoprint would be handy.
You would ssh to your pi and then edit your config.yaml using something like the following command.
nano ~/.octoprint/config.yaml
There's also a discussion over here on another similar set-up for Marlin.
You could also add babystepping buttons like this.
controls:
- children:
- command: M290 Z%(distance)s
input:
- default: 0.25
parameter: distance
- command: M290 Z-%(distance)s
input:
- default: 0.25
parameter: distance
layout: vertical
