We have been following this thread hoping for a solution (sudo update didnt work). We are using a BTT SKR Pro 1.1 on Marlin 2.0. We can find no reference to the USE_USB_Composite macro so am not sure where to add that to try it(conf.h or adv.h ?).
The strange thing is ANY new ISO works fine (no serial exceptions) in our RP 1B+ v1.2, but throws serial exceptions in our new RP 4B.
USE_USB_COMPOSITE is set in platformio.ini, it's set for some of the btt environments (set in default_envs in the [platformio] section). Depending on which one you use you may want to try commenting it out.
Apologies if this should have been posted as a new topic. I think this appears to be related?
Thank you for this thread, it has been a huge help in my troubleshooting. I am new to 3D Printing and to RPi so am learning as I go.
I have been experiencing this issue and have tried all the suggested fixes. Unfortunately, none have worked for me so far.
My details are as follows:
Printer: Ender 3 V2 with 4.2.7 mainboard
Octoprint Version: Initially 1.5.2, updated to 1.5.3 during troubleshooting Octopi Version: 0.17.0, updated to 0.18.0 during troubleshooting System: Raspberry Pi 4 Model B (Pi NOIR Camera module V2 connected) Browser: Google Chrome Version 88.0.4324.150 (Official Build) (64-bit)
Issue:
Experiencing the SerialError at random during prints longer than 60 minutes.
X,Y and Z stepper motors stop moving, but the hot end and bed stay at their assigned temperature. I have to reconnect to turn off the temps.
Firmware Tested:
Creality V1.0.1
Stable 2.0.7.2
Bugfix 2.0.x.x (15 Feb, 16 Feb and 17 Feb)
Troubleshooting
Fix?
Actual result
Moved closer to GPO (removed extension cable)
Failed after 60 minutes
Swapped USB cable
Printed directly from SD card
Caused Screen to lock up, so had to cycle power of the printer
Covered 5v pin of USB cable
Ran in Safe mode
Connected Printer to UPS
Failed after 40 minutes
Printed a shorter print (Less than 60 minutes)
Yes
Successful for 4 different models
Rolled back to Creality V1.0.1
Failed after 20 minutes
I've uploaded the Octoprint.log to my Google drive as it was too large to upload here.
I thank you for ready through this wall of text, I hope I have given enough information.
Yeah, since you've already pretty much ruled out firmware as a possible cause. If OctoPrint's not in the mix and your printer still doesn't print reliably, the fault can't possibly be with OctoPrint and is most likely with the firmware or the printer itself if just printing from SD won't even work.
