According to the configuration_adv.h
, it should:
// G2/G3 Arc Support
#define ARC_SUPPORT // Disable this feature to save ~3226 bytes
#if ENABLED(ARC_SUPPORT)
#define MM_PER_ARC_SEGMENT 1 // (mm) Length (or minimum length) of each arc segment
//#define ARC_SEGMENTS_PER_R 1 // Max segment length, MM_PER = Min
#define MIN_ARC_SEGMENTS 24 // Minimum number of segments in a complete circle
//#define ARC_SEGMENTS_PER_SEC 50 // Use feedrate to choose segment length (with MM_PER_ARC_SEGMENT as the minimum)
#define N_ARC_CORRECTION 25 // Number of interpolated segments between corrections
//#define ARC_P_CIRCLES // Enable the 'P' parameter to specify complete circles
//#define CNC_WORKSPACE_PLANES // Allow G2/G3 to operate in XY, ZX, or YZ planes
//#define SF_ARC_FIX // Enable only if using SkeinForge with "Arc Point" fillet procedure
#endif
But you better check on your downloads
