bought the Arducam Adjustable focus ov5647.. hitched it up to my rasberry pi 4 which is running octoprint.. works fine even with the octolapse... BUT out of focus..I installed the plugin to adjust the focus from Octoprint but i get an error "can't use i2c"... I did enable the i2c port... what could be wrong ?
Thanx
Iβm not near my computer right now. There are more instructions on the ArduCamFocus page.
Besides enabling I2C, you have to enable the kernel modules in /boot/config.txt
look in the pre-installation-requirements for details
Thank you moof & others....
I did enable the i2c and the kernel modules..
I also installed "pygame" and the python libraries....
At the Arducam pre-installation page  I copied and pasted the commands in my pi window...
if ! grep -Fxq "^#ArduCamFocus$" /boot/config.txt; then
sudo cat << end_of_file >> /boot/config.txt
#ArduCamFocus
dtparam=i2c_vc=on
dtparam=i2c_arm=on
end_of_file
fi
( then I hit ENTER )
I get    -bash: /boot/config.txt: Permission denied
( it's not letting me execute these commands )
I even tried entering them 1 line at a time... no luck...
Also, even if I can't get the plug-in to work, you would think
I could run the focus motor outside of Octoprint... no such luck...
Any ideas MOOF ( or others) ?? Thanks  LouRBK from CT.
I did change my password from the default "raspberry"
