Are there any working plugin for Zyyx+ 3D printer?
Hi
I have a Zyyx+ printer I would like to connect it to Octoprint version 1.3.9 (Raspberry Pi 3), but I can´t get it to work.
Are there a plugin that I need to install or is it just not possible to make it to work?
I think I have searched all over the internet without any luck. :disappointed_relieved:
I have tried to install the GPX plugin from the Plugin Manager, but that didn´t work.
Afterwards, I was not able to uninstall the plugin, so I had to make a new image.
The printer is running firmware version 5 and the firmware type is Makerbot/Salilfish.
The GPX profile is Replicator 2.
The printer came with a license for Simplify3D. The S3D can control the printer via USB.
Thanks in advance
Can you define this? It gives errors on the serial/USB connection, it causes the printer to smoke uncontrollably, ...?
There are no errors when connecting to the printer.
I just can´t control the printer or send a gcode from Octoprint to the printer.
When I installed the GPX plugin, Octoprint stalled and I had to put a new image on it.
I´m sorry, I know that it is not much to work with. I just don´t dare to install the plugin again.
I hope someone has any experince with Octoprint and Zyxx Printer and would be so kind to help me.
Well, I get this message in the terminal:
Connecting to: /dev/ttyACM0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x69f425d0, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N0 M110 N0*125
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
This is without the GPX plugin.
And this with the GPX plugin installed:
Changing monitoring state from "Offline" to "Error: Connection error, see Terminal tab"
Unexpected error while connecting to serial port: /dev/ttyACM0 IOError: '[Errno 2] No such file or directory: '/home/pi/.octoprint/data/GPX/gpx.ini'' @ comm.py:_openSerial:2469 (hook GPX)
