I have a Sovol SV01.
Pros. Comes beautifully pack in two parts. Literally 4 screw to connect the gantry to the base, plug in the two steppers on the gantry and install the Z endstop.
All materials that I've tried (PETG, PLA, Nylon, ABS, and ASA) so far stick to the bed when hot and pretty much fall off as it cools.
Although Sovol say it doesn't have TMC drivers (there's a silent board option), I find the loudest thing is the fans. (I bought a BTT SKR and TMC2709's because I assumed I'd need it - I've never bothered to install it.
The glass bed is ridiculously flat. Again I bought a BlTouch but don't use it. You're going to level the corners anyway and at that point you're good to go.
Runs vanilla Marlin and has a SV01 sample in configs.
Bed is 24v and heat quickly
Dual Z uses two steppers not a belt.
Cons Because the glass bed grips so well when hot you have to wait a while till it cools down to remove the printed part.
Limited nozzle temp (260) means you can't print PC.
I don't like the clone V6 Lite, probably going to change it for a genuine non-Lite at some point.
FWIW I don't own a Prusa cause I refuse to spend that much for a Mk3s kit and delivery on the mini is mad.
