Assembly language programming on the Pi
I just got a new book in my Christmas stocking and started working through it this evening: Raspberry Pi Assembly Language Programming by Stephen Smith, Apress (just published last month).
I'm pretty excited about the prospects. But of course since I wanted to work with the Pi 4B and play with Ubuntu 64-bit Server 19.10 I'm now attempting to translate the 32-bit ARM calls into ARM 64-bit so I'm a glutton for punishment. But I managed to make a hello world program.
.section .text
.global _start
_start:
        mov x0, #1
        ldr x1, =helloworld
        mov x2, #13
        mov x8, #0x40
        svc 0
        mov x0, #0x0
        mov x8, #93
        svc 0
.data
helloworld: .ascii "Hello World!\n"
Assembly Language is still state of the art.
I've done it in former day on the Z80 and the MC68000
I originally did it on the 8086 processor (woohoo). I wrote at least two TSRs.
Haven't done that since my mainframe days. Gave it up one I discovered higher level languages.
build
#!/bin/sh
if uname -snrvm | grep -q armv7l; then
    echo "32-bit detected"
    BITS=32
else
    echo "64-bit detected"
    BITS=64
fi
as -o helloworld.o helloworld-$BITS.s
ld -o bin/helloworld helloworld.o
helloworld-32.s
.section .text
.global _start
_start:
        mov r0, #1
        ldr r1, =helloworld
        mov r2, #13
        mov r7, #4
        svc 0
        mov r0, #0x0
        mov r7, #1
        svc 0
.data
So now it works on Ubuntu Server 19.10 64-bit and Raspbian Buster Lite 32-bit with the same project. :wink:
Assembly Language is blindingly Fast to run, execute, so quick it needs a delay in it some times
Yep - and the code is quite slim.
Improved makefile version of the build process. Just run make in the folder. The main part of the filename is simply edited at the top and used throughout.
makefile
PROJECT = upper
# Expected source files: *-32.s and *-64.s
BITS := $(shell getconf LONG_BIT)
OBJS = $(PROJECT).o
ifdef DEBUG
	DEBUGFLGS = -g
else
	DEBUGFLGS =
endif
%.o : %-$(BITS).s
	as $(DEBUGFLGS) -o $@	$<
$(PROJECT): $(OBJS)
	ld  -o bin/$(PROJECT)	$(OBJS)
On a related note for others, that getconf LONG_BIT command will natively return either 32 or 64 on the command line and is great for programmatically making decisions.
$ getconf -a
LINK_MAX                           65000
_POSIX_LINK_MAX                    65000
MAX_CANON                          255
_POSIX_MAX_CANON                   255
MAX_INPUT                          255
_POSIX_MAX_INPUT                   255
NAME_MAX                           255
_POSIX_NAME_MAX                    255
PATH_MAX                           4096
_POSIX_PATH_MAX                    4096
PIPE_BUF                           4096
_POSIX_PIPE_BUF                    4096
SOCK_MAXBUF
_POSIX_ASYNC_IO
_POSIX_CHOWN_RESTRICTED            1
_POSIX_NO_TRUNC                    1
_POSIX_PRIO_IO
_POSIX_SYNC_IO
_POSIX_VDISABLE                    0
ARG_MAX                            2097152
ATEXIT_MAX                         2147483647
CHAR_BIT                           8
CHAR_MAX                           255
CHAR_MIN                           0
CHILD_MAX                          29184
CLK_TCK                            100
INT_MAX                            2147483647
INT_MIN                            -2147483648
IOV_MAX                            1024
LOGNAME_MAX                        256
LONG_BIT                           32
MB_LEN_MAX                         16
NGROUPS_MAX                        65536
NL_ARGMAX                          4096
NL_LANGMAX                         2048
NL_MSGMAX                          2147483647
NL_NMAX                            2147483647
NL_SETMAX                          2147483647
NL_TEXTMAX                         2147483647
NSS_BUFLEN_GROUP                   1024
NSS_BUFLEN_PASSWD                  1024
NZERO                              20
OPEN_MAX                           1024
PAGESIZE                           4096
PAGE_SIZE                          4096
PASS_MAX                           8192
PTHREAD_DESTRUCTOR_ITERATIONS      4
PTHREAD_KEYS_MAX                   1024
PTHREAD_STACK_MIN                  16384
PTHREAD_THREADS_MAX
SCHAR_MAX                          127
SCHAR_MIN                          -128
SHRT_MAX                           32767
SHRT_MIN                           -32768
SSIZE_MAX                          32767
TTY_NAME_MAX                       32
TZNAME_MAX
UCHAR_MAX                          255
UINT_MAX                           4294967295
UIO_MAXIOV                         1024
ULONG_MAX                          4294967295
USHRT_MAX                          65535
WORD_BIT                           32
_AVPHYS_PAGES                      944720
_NPROCESSORS_CONF                  4
_NPROCESSORS_ONLN                  4
_PHYS_PAGES                        999946
_POSIX_ARG_MAX                     2097152
_POSIX_ASYNCHRONOUS_IO             200809
_POSIX_CHILD_MAX                   29184
_POSIX_FSYNC                       200809
_POSIX_JOB_CONTROL                 1
_POSIX_MAPPED_FILES                200809
_POSIX_MEMLOCK                     200809
_POSIX_MEMLOCK_RANGE               200809
_POSIX_MEMORY_PROTECTION           200809
_POSIX_MESSAGE_PASSING             200809
_POSIX_NGROUPS_MAX                 65536
_POSIX_OPEN_MAX                    1024
_POSIX_PII
_POSIX_PII_INTERNET
_POSIX_PII_INTERNET_DGRAM
_POSIX_PII_INTERNET_STREAM
_POSIX_PII_OSI
_POSIX_PII_OSI_CLTS
_POSIX_PII_OSI_COTS
_POSIX_PII_OSI_M
_POSIX_PII_SOCKET
_POSIX_PII_XTI
_POSIX_POLL
_POSIX_PRIORITIZED_IO              200809
_POSIX_PRIORITY_SCHEDULING         200809
_POSIX_REALTIME_SIGNALS            200809
_POSIX_SAVED_IDS                   1
_POSIX_SELECT
_POSIX_SEMAPHORES                  200809
_POSIX_SHARED_MEMORY_OBJECTS       200809
_POSIX_SSIZE_MAX                   32767
_POSIX_STREAM_MAX                  16
_POSIX_SYNCHRONIZED_IO             200809
_POSIX_THREADS                     200809
_POSIX_THREAD_ATTR_STACKADDR       200809
_POSIX_THREAD_ATTR_STACKSIZE       200809
_POSIX_THREAD_PRIORITY_SCHEDULING  200809
_POSIX_THREAD_PRIO_INHERIT         200809
_POSIX_THREAD_PRIO_PROTECT         200809
_POSIX_THREAD_ROBUST_PRIO_INHERIT
_POSIX_THREAD_ROBUST_PRIO_PROTECT
_POSIX_THREAD_PROCESS_SHARED       200809
_POSIX_THREAD_SAFE_FUNCTIONS       200809
_POSIX_TIMERS                      200809
TIMER_MAX
_POSIX_TZNAME_MAX
_POSIX_VERSION                     200809
_T_IOV_MAX
_XOPEN_CRYPT
_XOPEN_ENH_I18N                    1
_XOPEN_LEGACY                      1
_XOPEN_REALTIME                    1
_XOPEN_REALTIME_THREADS            1
_XOPEN_SHM                         1
_XOPEN_UNIX                        1
_XOPEN_VERSION                     700
_XOPEN_XCU_VERSION                 4
_XOPEN_XPG2                        1
_XOPEN_XPG3                        1
_XOPEN_XPG4                        1
BC_BASE_MAX                        99
BC_DIM_MAX                         2048
BC_SCALE_MAX                       99
BC_STRING_MAX                      1000
CHARCLASS_NAME_MAX                 2048
COLL_WEIGHTS_MAX                   255
EQUIV_CLASS_MAX
EXPR_NEST_MAX                      32
LINE_MAX                           2048
POSIX2_BC_BASE_MAX                 99
POSIX2_BC_DIM_MAX                  2048
POSIX2_BC_SCALE_MAX                99
POSIX2_BC_STRING_MAX               1000
POSIX2_CHAR_TERM                   200809
POSIX2_COLL_WEIGHTS_MAX            255
POSIX2_C_BIND                      200809
POSIX2_C_DEV                       200809
POSIX2_C_VERSION                   200809
POSIX2_EXPR_NEST_MAX               32
POSIX2_FORT_DEV
POSIX2_FORT_RUN
_POSIX2_LINE_MAX                   2048
POSIX2_LOCALEDEF                   200809
POSIX2_RE_DUP_MAX                  32767
POSIX2_SW_DEV                      200809
POSIX2_UPE
POSIX2_VERSION                     200809
RE_DUP_MAX                         32767
PATH                               /bin:/usr/bin
CS_PATH                            /bin:/usr/bin
LFS_CFLAGS                         -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
LFS_LDFLAGS
LFS_LIBS
LFS_LINTFLAGS                      -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
LFS64_CFLAGS                       -D_LARGEFILE64_SOURCE
LFS64_LDFLAGS
LFS64_LIBS
LFS64_LINTFLAGS                    -D_LARGEFILE64_SOURCE
_XBS5_WIDTH_RESTRICTED_ENVS        XBS5_ILP32_OFF32
XBS5_ILP32_OFFBIG
XBS5_ILP32_OFFBIG
_XBS5_ILP32_OFF32                  1
XBS5_ILP32_OFF32_CFLAGS
XBS5_ILP32_OFF32_LDFLAGS
XBS5_ILP32_OFF32_LIBS
XBS5_ILP32_OFF32_LINTFLAGS
_XBS5_ILP32_OFFBIG                 1
XBS5_ILP32_OFFBIG_CFLAGS           -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
XBS5_ILP32_OFFBIG_LDFLAGS
XBS5_ILP32_OFFBIG_LIBS
XBS5_ILP32_OFFBIG_LINTFLAGS
_XBS5_LP64_OFF64
XBS5_LP64_OFF64_CFLAGS
XBS5_LP64_OFF64_LDFLAGS
XBS5_LP64_OFF64_LIBS
XBS5_LP64_OFF64_LINTFLAGS
_XBS5_LPBIG_OFFBIG
XBS5_LPBIG_OFFBIG_CFLAGS
XBS5_LPBIG_OFFBIG_LDFLAGS
XBS5_LPBIG_OFFBIG_LIBS
XBS5_LPBIG_OFFBIG_LINTFLAGS
_POSIX_V6_ILP32_OFF32              1
POSIX_V6_ILP32_OFF32_CFLAGS
POSIX_V6_ILP32_OFF32_LDFLAGS
POSIX_V6_ILP32_OFF32_LIBS
POSIX_V6_ILP32_OFF32_LINTFLAGS
_POSIX_V6_WIDTH_RESTRICTED_ENVS    POSIX_V6_ILP32_OFF32
POSIX_V6_ILP32_OFFBIG
_POSIX_V6_ILP32_OFFBIG             1
POSIX_V6_ILP32_OFFBIG_CFLAGS       -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
POSIX_V6_ILP32_OFFBIG_LDFLAGS
POSIX_V6_ILP32_OFFBIG_LIBS
POSIX_V6_ILP32_OFFBIG_LINTFLAGS
_POSIX_V6_LP64_OFF64
POSIX_V6_LP64_OFF64_CFLAGS
POSIX_V6_LP64_OFF64_LDFLAGS
POSIX_V6_LP64_OFF64_LIBS
POSIX_V6_LP64_OFF64_LINTFLAGS
_POSIX_V6_LPBIG_OFFBIG
POSIX_V6_LPBIG_OFFBIG_CFLAGS
POSIX_V6_LPBIG_OFFBIG_LDFLAGS
POSIX_V6_LPBIG_OFFBIG_LIBS
POSIX_V6_LPBIG_OFFBIG_LINTFLAGS
_POSIX_V7_ILP32_OFF32              1
POSIX_V7_ILP32_OFF32_CFLAGS
POSIX_V7_ILP32_OFF32_LDFLAGS
POSIX_V7_ILP32_OFF32_LIBS
POSIX_V7_ILP32_OFF32_LINTFLAGS
_POSIX_V7_WIDTH_RESTRICTED_ENVS    POSIX_V7_ILP32_OFF32
POSIX_V7_ILP32_OFFBIG
_POSIX_V7_ILP32_OFFBIG             1
POSIX_V7_ILP32_OFFBIG_CFLAGS       -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
POSIX_V7_ILP32_OFFBIG_LDFLAGS
POSIX_V7_ILP32_OFFBIG_LIBS
POSIX_V7_ILP32_OFFBIG_LINTFLAGS
_POSIX_V7_LP64_OFF64
POSIX_V7_LP64_OFF64_CFLAGS
POSIX_V7_LP64_OFF64_LDFLAGS
POSIX_V7_LP64_OFF64_LIBS
POSIX_V7_LP64_OFF64_LINTFLAGS
_POSIX_V7_LPBIG_OFFBIG
POSIX_V7_LPBIG_OFFBIG_CFLAGS
POSIX_V7_LPBIG_OFFBIG_LDFLAGS
POSIX_V7_LPBIG_OFFBIG_LIBS
POSIX_V7_LPBIG_OFFBIG_LINTFLAGS
_POSIX_ADVISORY_INFO               200809
_POSIX_BARRIERS                    200809
_POSIX_BASE
_POSIX_C_LANG_SUPPORT
_POSIX_C_LANG_SUPPORT_R
_POSIX_CLOCK_SELECTION             200809
_POSIX_CPUTIME                     200809
_POSIX_THREAD_CPUTIME              200809
_POSIX_DEVICE_SPECIFIC
_POSIX_DEVICE_SPECIFIC_R
_POSIX_FD_MGMT
_POSIX_FIFO
_POSIX_PIPE
_POSIX_FILE_ATTRIBUTES
_POSIX_FILE_LOCKING
_POSIX_FILE_SYSTEM
_POSIX_MONOTONIC_CLOCK             200809
_POSIX_MULTI_PROCESS
_POSIX_SINGLE_PROCESS
_POSIX_NETWORKING
_POSIX_READER_WRITER_LOCKS         200809
_POSIX_SPIN_LOCKS                  200809
_POSIX_REGEXP                      1
_REGEX_VERSION
_POSIX_SHELL                       1
_POSIX_SIGNALS
_POSIX_SPAWN                       200809
_POSIX_SPORADIC_SERVER
_POSIX_THREAD_SPORADIC_SERVER
_POSIX_SYSTEM_DATABASE
_POSIX_SYSTEM_DATABASE_R
_POSIX_TIMEOUTS                    200809
_POSIX_TYPED_MEMORY_OBJECTS
_POSIX_USER_GROUPS
_POSIX_USER_GROUPS_R
POSIX2_PBS
POSIX2_PBS_ACCOUNTING
POSIX2_PBS_LOCATE
POSIX2_PBS_TRACK
POSIX2_PBS_MESSAGE
SYMLOOP_MAX
STREAM_MAX                         16
AIO_LISTIO_MAX
AIO_MAX
AIO_PRIO_DELTA_MAX                 20
DELAYTIMER_MAX                     2147483647
HOST_NAME_MAX                      64
LOGIN_NAME_MAX                     256
MQ_OPEN_MAX
MQ_PRIO_MAX                        32768
_POSIX_DEVICE_IO
_POSIX_TRACE
_POSIX_TRACE_EVENT_FILTER
_POSIX_TRACE_INHERIT
_POSIX_TRACE_LOG
RTSIG_MAX                          32
SEM_NSEMS_MAX
SEM_VALUE_MAX                      2147483647
SIGQUEUE_MAX                       29184
FILESIZEBITS                       64
POSIX_ALLOC_SIZE_MIN               4096
POSIX_REC_INCR_XFER_SIZE
POSIX_REC_MAX_XFER_SIZE
POSIX_REC_MIN_XFER_SIZE            4096
POSIX_REC_XFER_ALIGN               4096
SYMLINK_MAX
GNU_LIBC_VERSION                   glibc 2.28
GNU_LIBPTHREAD_VERSION             NPTL 2.28
POSIX2_SYMLINKS                    1
LEVEL1_ICACHE_SIZE                 0
LEVEL1_ICACHE_ASSOC                0
LEVEL1_ICACHE_LINESIZE             0
LEVEL1_DCACHE_SIZE                 0
LEVEL1_DCACHE_ASSOC                0
LEVEL1_DCACHE_LINESIZE             0
LEVEL2_CACHE_SIZE                  0
LEVEL2_CACHE_ASSOC                 0
LEVEL2_CACHE_LINESIZE              0
LEVEL3_CACHE_SIZE                  0
LEVEL3_CACHE_ASSOC                 0
LEVEL3_CACHE_LINESIZE              0
LEVEL4_CACHE_SIZE                  0
LEVEL4_CACHE_ASSOC                 0
LEVEL4_CACHE_LINESIZE              0
IPV6                               200809
RAW_SOCKETS                        200809
_POSIX_IPV6                        200809
_POSIX_RAW_SOCKETS                 200809
Additionally (noting that I'm on a Pi 4B 4GB for this)...
$ cat /proc/meminfo
MemTotal:        3999784 kB
MemFree:         3777568 kB
MemAvailable:    3775124 kB
Buffers:           17508 kB
Cached:            93272 kB
SwapCached:            0 kB
Active:            90948 kB
Inactive:          34104 kB
Active(anon):      14556 kB
Inactive(anon):     8336 kB
Active(file):      76392 kB
Inactive(file):    25768 kB
Unevictable:          16 kB
Mlocked:              16 kB
HighTotal:       3264512 kB
HighFree:        3147080 kB
LowTotal:         735272 kB
LowFree:          630488 kB
SwapTotal:        102396 kB
SwapFree:         102396 kB
Dirty:                 8 kB
Writeback:             0 kB
AnonPages:         14292 kB
Mapped:            21136 kB
Shmem:              8616 kB
Slab:              39964 kB
SReclaimable:      17696 kB
SUnreclaim:        22268 kB
KernelStack:         984 kB
PageTables:          988 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     2102288 kB
Committed_AS:     100388 kB
VmallocTotal:     245760 kB
VmallocUsed:           0 kB
VmallocChunk:          0 kB
Percpu:              608 kB
CmaTotal:         262144 kB
CmaFree:          222976 kB
Correct, much shorter code Ld A, 91; etc
Faster running code
OMG I'm now at the part where I'm controlling GPIO pins with assembly. booya!
Toggling a GPIO pin on Rasbian ARMv7 in assembly language (32-bit)
Here's the code if you'd like to play along. Note the follow-up files in the next posts.
flashpin26-32.s
@ Assembler program to toggle BCM pin26 connected to the
@ Raspberry Pi GPIO port.
@ r6 - loop variable to flash lights 10 times
.include "gpiomacros-32.s"
.global _start	                            @ Provide program starting address to linker
_start:
        GPIOExp         pin26
        nanoSleep
        GPIODirOut      pin26
        @ setup a loop counter for 10 iterations
        mov             r6, #10
loop:
        GPIOWrite       pin26, high
        nanoSleep
        nanoSleep
        nanoSleep
        nanoSleep
        nanoSleep
        nanoSleep
        nanoSleep
        nanoSleep
        nanoSleep
        nanoSleep
        GPIOWrite       pin26, low
        nanoSleep
        nanoSleep
        nanoSleep
        nanoSleep
        nanoSleep
        nanoSleep
        nanoSleep
        nanoSleep
        nanoSleep
        nanoSleep
        @decrement loop counter and see if we loop
        subs            r6, #1              @ Subtract 1 from loop register setting status register
        bne             loop                @ If we haven't counted down to 0 then loop
_end:
        GPIOUnexp       pin26
        mov             R0, #0              @ Use 0 return code
        mov             R7, #1              @ Service command code 1 terminates this program
        svc             0                   @ Linux command to terminate program
pin26:      .asciz  "26"
low:        .asciz  "0"
high:       .asciz  "1"
Connect two wires from BCM 26 to the Ground pin next to it to your multimeter or oscilloscope:
# Copy these files into a folder under the Pi's home and change to it
mkdir bin
make
bin/flashpin26
# The multimeter should toggle between 3.3V and 0.0V for ten cycles
You should be able to use this technique to toggle on or off any of the pins which aren't ground, which don't supply voltage, etc. It's best to use BCM pins: 5, 6, 17, 27, 22, 23, 24, 25, 26 (saving the remaining pins for other things). I usually find one of these that's next to a ground pin so that it makes things easier.
gpiomacros-32.s
@ R8 - file descriptor.
.include "fileio-32.s"
@ Macro nanoSleep to sleep .1 second
@ Calls Linux nanosleep entry point which is function 162.
@ Pass a reference to a timespec in both r0 and r1
@ First is input time to sleep in seconds and nanoseconds.
@ Second is time left to sleep if interrupted (which we ignore)
.macro  nanoSleep
        ldr         r0, =timespecsec
        ldr         r1, =timespecsec
        mov         r7, #sys_nanosleep
        svc         0
.endm
.macro  GPIOExp     pin
        openFile    gpioexp
        mov         r8, r0                  @ save the file descriptor
        writeFile   r8, \pin, #2
        flushClose  r8
.endm
.macro  GPIOUnexp   pin
        openFile    gpiounexp
        flushClose  r8
.endm
.macro  GPIODirOut   pin
        @ copy pin into filename pattern
        ldr         r1, =\pin
        ldr         r2, =gpiopinfile
        add         r2, #20
        ldrb        r3, [r1], #1            @ load pin and post increment
        strb        r3, [r2], #1            @ store to filename and post increment
        ldrb        r3, [r1]
        strb        r3, [r2]
        openFile    gpiopinfile
        writeFile   r8, outstr, #3
        flushClose  r8
.endm
.macro  GPIOWrite   pin, value
        ldr         r1, =\pin
        ldr         r2, =gpiovaluefile
        add         r2, #20
        ldrb        r3, [r1]
        strb        r3, [r2]
        openFile    gpiovaluefile
        writeFile   r8, \value, #1
        flushClose  r8
.endm
.data
timespecsec:    .word   0
timespecnano:   .word   100000000
gpioexp:        .asciz  "/sys/class/gpio/export"
gpiounexp:      .asciz  "/sys/class/gpio/unexport"
gpiopinfile:    .asciz "/sys/class/gpio/gpioxx/direction"
gpiovaluefile:  .asciz "/sys/class/gpio/gpioxx/value"
outstr:         .asciz  "out"
                .align  2                   @ save users of this file having to do this.
.text
fileio-32.s
@ Various macros to perform file I/O
@ The fd parameter needs to be a register.
@ Uses R0, R1, R7.
@ Return code is in R0.
.include "unistd-32.s"
.equ    O_RDONLY,   0
.equ    O_WRONLY,   1
.equ    O_CREAT,    0100
.equ    O_RDWR,     2
.equ    O_SYNC,     04010000
.equ    O_CLOEXEC,  02000000
.equ    S_RDWR,     0666
.macro  openFile    fileName
        ldr         r0, =\fileName
        ldr         r1, =flags
        ldr         r1, [r1]
        mov         r2, #S_RDWR             @ RW access rights
        mov         r7, #sys_open
        svc         0
.endm
.macro  readFile    fd, buffer, length
        mov         r0, \fd                 @ file descriptor
        ldr         r1, =\buffer
        mov         r2, #\length
        mov         r7, #sys_read
        svc         0
.endm
.macro  writeFile   fd, buffer, length
        ldr         r1, =\buffer
        mov         r2, \length
        mov         r7, #sys_write
        svc         0
.endm
.macro  flushClose  fd
        @fsync syscall
        mov         r0, \fd
        mov         r7, #sys_fsync
        svc         0
        @close syscall
        mov         r0, \fd
        mov         r7, #sys_close
        svc         0
.endm
.data
flags: .word O_RDWR+O_SYNC+O_CLOEXEC
.text
unistd-32.s
@ Defines for the Linux system calls.
@ This list is from Raspbian Buster
.EQU sys_restart_syscall,                     0    @ restart a system call after interruption by a stop signal
.EQU sys_exit,                                1    @ cause normal process termination
.EQU sys_fork,                                2    @ create a child process
.EQU sys_read,                                3    @ read from a file descriptor
.EQU sys_write,                               4    @ write to a file descriptor
.EQU sys_open,                                5    @ open and possibly create a file
.EQU sys_close,                               6    @ close a file descriptor
.EQU sys_creat,                               8    @ create a new file or rewrite an existing one
.EQU sys_link,                                9    @ make a new name for a file
.EQU sys_unlink,                             10    @ delete a name and possibly the file it refers to
.EQU sys_execve,                             11    @ execute program
.EQU sys_chdir,                              12    @ change working directory
.EQU sys_mknod,                              14    @ create a special or ordinary file
.EQU sys_chmod,                              15    @ change file mode bits
.EQU sys_lchown,                             16    @ change the owner and group of a symbolic link
.EQU sys_lseek,                              19    @ reposition read/write file offset
.EQU sys_getpid,                             20    @ get process identification
.EQU sys_mount,                              21    @ mount filesystem
.EQU sys_setuid,                             23    @ set user identity
.EQU sys_getuid,                             24    @ get user identity
.EQU sys_ptrace,                             26    @ process trace
.EQU sys_pause,                              29    @ wait for signal
.EQU sys_access,                             33    @ check user's permissions for a file
.EQU sys_nice,                               34    @ change process priority
.EQU sys_sync,                               36    @ commit filesystem caches to disk
.EQU sys_kill,                               37    @ send signal to a process
.EQU sys_rename,                             38    @ change the name or location of a file
.EQU sys_mkdir,                              39    @ create a directory
.EQU sys_rmdir,                              40    @ delete a directory
.EQU sys_dup,                                41    @ duplicate a file descriptor
.EQU sys_pipe,                               42    @ create pipe
.EQU sys_times,                              43    @ get process times
.EQU sys_brk,                                45    @ change data segment size
.EQU sys_setgid,                             46    @ set group identity
.EQU sys_getgid,                             47    @ get group identity
.EQU sys_geteuid,                            49    @ get user identity
.EQU sys_getegid,                            50    @ get group identity
.EQU sys_acct,                               51    @ switch process accounting on or off
.EQU sys_umount2,                            52    @ unmount filesystem
.EQU sys_ioctl,                              54    @ control device
.EQU sys_fcntl,                              55    @ manipulate file descriptor
.EQU sys_setpgid,                            57    @ set process group
.EQU sys_umask,                              60    @ set file mode creation mask
.EQU sys_chroot,                             61    @ change root directory
.EQU sys_ustat,                              62    @ get filesystem statistics
.EQU sys_dup2,                               63    @ duplicate a file descriptor
.EQU sys_getppid,                            64    @ get the parent process ID
.EQU sys_getpgrp,                            65    @ get process group
.EQU sys_setsid,                             66    @ creates a session and sets the process group ID
.EQU sys_sigaction,                          67    @ examine and change a signal action
.EQU sys_setreuid,                           70    @ set real and/or effective user ID
.EQU sys_setregid,                           71    @ set real and/or effective group ID
.EQU sys_sigsuspend,                         72    @ wait for a signal
.EQU sys_sigpending,                         73    @ examine pending signals
.EQU sys_sethostname,                        74    @ set hostname
.EQU sys_setrlimit,                          75    @ control maximum resource consumption
.EQU sys_getrusage,                          77    @ get resource usage
.EQU sys_gettimeofday,                       78    @ get time
.EQU sys_settimeofday,                       79    @ set time
.EQU sys_getgroups,                          80    @ get list of supplementary group IDs
.EQU sys_setgroups,                          81    @ set list of supplementary group IDs
.EQU sys_symlink,                            83    @ make a new name for a file
.EQU sys_readlink,                           85    @ read value of a symbolic link
.EQU sys_uselib,                             86    @load shared library
.EQU sys_swapon,                             87    @ start swapping to file/device
.EQU sys_reboot,                             88    @ reboot
.EQU sys_munmap,                             91    @ unmap files or devices into memory
.EQU sys_truncate,                           92    @ truncate a file to a specified length
.EQU sys_ftruncate,                          93    @ truncate a file to a specified length
.EQU sys_fchmod,                             94    @ change permissions of a file
.EQU sys_fchown,                             95    @ change ownership of a file
.EQU sys_getpriority,                        96    @ get program scheduling priority
.EQU sys_setpriority,                        97    @ set program scheduling priority
.EQU sys_statfs,                             99    @ get filesystem statistics
.EQU sys_fstatfs,                           100    @ get filesystem statistics
.EQU sys_syslog,                            103    @ read and/or clear kernel message ring buffer; set console_loglevel
.EQU sys_setitimer,                         104    @ set value of an interval timer
.EQU sys_getitimer,                         105    @ get value of an interval timer
.EQU sys_stat,                              106    @ get file status
.EQU sys_lstat,                             107    @ get file status
.EQU sys_fstat,                             108    @ get file status
.EQU sys_vhangup,                           111    @ virtually hangup the current terminal
.EQU sys_wait4,                             114    @ wait for process to change state, BSD style
.EQU sys_swapoff,                           115    @ stop swapping to file/device
.EQU sys_sysinfo,                           116    @ return system information
.EQU sys_fsync,                             118    @ synchronize a file's in-core state with storage
.EQU sys_sigreturn,                         119    @ return  from  signal handler and cleanup stack frame
.EQU sys_clone,                             120    @ create a child process
.EQU sys_setdomainname,                     121    @ set NIS domain name
.EQU sys_uname,                             122    @ get name and information about current kernel
.EQU sys_adjtimex,                          124    @ tune kernel clock
.EQU sys_mprotect,                          125    @ set protection on a region of memory
.EQU sys_sigprocmask,                       126    @ examine and change blocked signals
.EQU sys_init_module,                       128    @ load a kernel module
.EQU sys_delete_module,                     129    @ unload a kernel module
.EQU sys_quotactl,                          131    @ manipulate disk quotas
.EQU sys_getpgid,                           132    @ get process group
.EQU sys_fchdir,                            133    @ change working directory
.EQU sys_bdflush,                           134    @ start, flush, or tune buffer-dirty-flush daemon
.EQU sys_sysfs,                             135    @ get filesystem type information
.EQU sys_personality,                       136    @ set the process execution domain
.EQU sys_setfsuid,                          138    @ set user identity used for filesystem checks
.EQU sys_setfsgid,                          139    @ set group identity used for filesystem checks
.EQU sys__llseek,                           140    @ reposition read/write file offset
.EQU sys_getdents,                          141    @ get directory entries
.EQU sys__newselect,                        142    @ synchronous I/O multiplexing
.EQU sys_flock,                             143    @ apply or remove an advisory lock on an open file
.EQU sys_msync,                             144    @ synchronize a file with a memory map
.EQU sys_readv,                             145    @ read data into multiple buffers
.EQU sys_writev,                            146    @ write data into multiple buffers
.EQU sys_getsid,                            147    @ get session ID
.EQU sys_fdatasync,                         148    @ synchronize a file's in-core state with storage device
.EQU sys__sysctl,                           149    @ read/write system parameters
.EQU sys_mlock,                             150    @ lock memory
.EQU sys_munlock,                           151    @ unlock memory
.EQU sys_mlockall,                          152    @ lock memory
.EQU sys_munlockall,                        153    @ unlock memory
.EQU sys_sched_setparam,                    154    @ set scheduling parameters
.EQU sys_sched_getparam,                    155    @ get scheduling parameters
.EQU sys_sched_setscheduler,                156    @ set and get scheduling policy/parameters
.EQU sys_sched_getscheduler,                157    @ set and get scheduling policy/parameters
.EQU sys_sched_yield,                       158    @ yield the processor
.EQU sys_sched_get_priority_max,            159    @ get static priority max
.EQU sys_sched_get_priority_min,            160    @ get static priority min
.EQU sys_sched_rr_get_interval,             161    @ get  the  SCHED_RR  interval  for the named process
.EQU sys_nanosleep,                         162    @ high-resolution sleep
.EQU sys_mremap,                            163    @ remap a virtual memory address
.EQU sys_setresuid,                         164    @ set real, effective and saved user ID
.EQU sys_getresuid,                         165    @ get real, effective and saved user ID
.EQU sys_poll,                              168    @ wait for some event on a file descriptor
.EQU sys_nfsservctl,                        169    @ syscall interface to kernel nfs daemon
.EQU sys_setresgid,                         170    @ set real, effective and saved group ID
.EQU sys_getresgid,                         171    @ get real, effective and saved group ID
.EQU sys_prctl,                             172    @ operations on a process
.EQU sys_rt_sigreturn,                      173    @ return  from  signal handler and cleanup stack frame
.EQU sys_rt_sigaction,                      174    @ examine and change a signal action
.EQU sys_rt_sigprocmask,                    175    @ examine and change blocked signals
.EQU sys_rt_sigpending,                     176    @ examine pending signals
.EQU sys_rt_sigtimedwait,                   177    @ synchronously wait for queued signals
.EQU sys_rt_sigqueueinfo,                   178    @ queue a signal and data
.EQU sys_rt_sigsuspend,                     179    @ wait for a signal
.EQU sys_pread64,                           180    @ read from a file descriptor at a given offset
.EQU sys_pwrite64,                          181    @ write to a file descriptor at a given offset
.EQU sys_chown,                             182    @ change ownership of a file
.EQU sys_getcwd,                            183    @ get current working directory
.EQU sys_capget,                            184    @ get capabilities of thread(s)
.EQU sys_capset,                            185    @ set capabilities of thread(s)
.EQU sys_sigaltstack,                       186    @ set and/or get signal stack context
.EQU sys_sendfile,                          187    @ transfer data between file descriptors
.EQU sys_vfork,                             190    @ create a child process and block parent
.EQU sys_ugetrlimit,                        191    @ get resource limits
.EQU sys_mmap2,                             192    @ map files or devices into memory
.EQU sys_truncate64,                        193    @ truncate a file to a specified length
.EQU sys_ftruncate64,                       194    @ truncate a file to a specified length
.EQU sys_stat64,                            195    @ get file status
.EQU sys_lstat64,                           196    @ get file status
.EQU sys_fstat64,                           197    @ get file status
.EQU sys_lchown32,                          198    @ change ownership of a file
.EQU sys_getuid32,                          199    @ get user identity
.EQU sys_getgid32,                          200    @ get group identity
.EQU sys_geteuid32,                         201    @ get user identity
.EQU sys_getegid32,                         202    @ get group identity
.EQU sys_setreuid32,                        203    @ set real and/or effective user ID
.EQU sys_setregid32,                        204    @ set real and/or effective group ID
.EQU sys_getgroups32,                       205    @ get list of supplementary group IDs
.EQU sys_setgroups32,                       206    @ set list of supplementary group IDs
.EQU sys_fchown32,                          207    @ change ownership of a file
.EQU sys_setresuid32,                       208    @ set real, effective and saved user ID
.EQU sys_getresuid32,                       209    @ get real, effective and saved user ID
.EQU sys_setresgid32,                       210    @ set real, effective and saved group ID
.EQU sys_getresgid32,                       211    @ get real, effective and saved group ID
.EQU sys_chown32,                           212    @ change ownership of a file
.EQU sys_setuid32,                          213    @ set user identity
.EQU sys_setgid32,                          214    @ set group identity
.EQU sys_setfsuid32,                        215    @ set user identity used for filesystem checks
.EQU sys_setfsgid32,                        216    @ set group identity used for filesystem checks
.EQU sys_getdents64,                        217    @ get directory entries
.EQU sys_pivot_root,                        218    @ change the root filesystem
.EQU sys_mincore,                           219    @ determine whether pages are resident in memory
.EQU sys_madvise,                           220    @ give advice about use of memory
.EQU sys_fcntl64,                           221    @ manipulate file descriptor
.EQU sys_gettid,                            224    @ get thread identification
.EQU sys_readahead,                         225    @ initiate file readahead into page cache
.EQU sys_setxattr,                          226    @ set an extended attribute value
.EQU sys_lsetxattr,                         227    @ set an extended attribute value
.EQU sys_fsetxattr,                         228    @ set an extended attribute value
.EQU sys_getxattr,                          229    @ retrieve an extended attribute value
.EQU sys_lgetxattr,                         230    @ retrieve an extended attribute value
.EQU sys_fgetxattr,                         231    @ retrieve an extended attribute value
.EQU sys_listxattr,                         232    @ list extended attribute names
.EQU sys_llistxattr,                        233    @ list extended attribute names
.EQU sys_flistxattr,                        234    @ list extended attribute names
.EQU sys_removexattr,                       235    @ remove  an  extended attribute
.EQU sys_lremovexattr,                      236    @ remove  an  extended attribute
.EQU sys_fremovexattr,                      237    @ remove  an  extended attribute
.EQU sys_tkill,                             238    @ send a signal to a thread
.EQU sys_sendfile64,                        239    @ transfer data between file descriptors
.EQU sys_futex,                             240    @ fast user-space locking
.EQU sys_sched_setaffinity,                 241    @ set a thread's CPU affinity mask
.EQU sys_sched_getaffinity,                 242    @ get a thread's CPU affinity mask
.EQU sys_io_setup,                          243    @ create an asynchronous I/O context
.EQU sys_io_destroy,                        244    @ destroy an asynchronous I/O context
.EQU sys_io_getevents,                      245    @ read asynchronous I/O events from the completion queue
.EQU sys_io_submit,                         246    @ submit asynchronous I/O blocks for processing
.EQU sys_io_cancel,                         247    @ cancel an outstanding asynchronous I/O operation
.EQU sys_exit_group,                        248    @ exit all threads in a process
.EQU sys_lookup_dcookie,                    249    @ return a directory entry's path
.EQU sys_epoll_create,                      250    @ open an epoll file descriptor
.EQU sys_epoll_ctl,                         251    @ control interface for an epoll file descriptor
.EQU sys_epoll_wait,                        252    @ wait  for  an I/O event on an epoll file descriptor
.EQU sys_remap_file_pages,                  253    @ create a nonlinear file mapping
.EQU sys_set_tid_address,                   256    @ set pointer to thread ID
.EQU sys_timer_create,                      257    @ create a POSIX per-process timer
.EQU sys_timer_settime,                     258    @arm/disarm state of POSIX per-process timer
.EQU sys_timer_gettime,                     259    @ fetch state of POSIX per-process timer
.EQU sys_timer_getoverrun,                  260    @ get overrun count for a POSIX per-process timer
.EQU sys_timer_delete,                      261    @ delete a POSIX per-process timer
.EQU sys_clock_settime,                     262    @ clock and timer functions
.EQU sys_clock_gettime,                     263    @ clock and timer functions
.EQU sys_clock_getres,                      264    @ clock and timer functions
.EQU sys_clock_nanosleep,                   265    @ high-resolution sleep with specifiable clock
.EQU sys_statfs64,                          266    @ get filesystem statistics
.EQU sys_fstatfs64,                         267    @ get filesystem statistics
.EQU sys_tgkill,                            268    @ send a signal to a thread
.EQU sys_utimes,                            269    @ change file last access and modification times
.EQU sys_arm_fadvise64_64,                  270    @ predeclare an access pattern for file data
.EQU sys_pciconfig_iobase,                  271    @ pci device information handling
.EQU sys_pciconfig_read,                    272    @ pci device information handling
.EQU sys_pciconfig_write,                   273    @ pci device information handling
.EQU sys_mq_open,                           274    @ open a message queue
.EQU sys_mq_unlink,                         275    @ remove a message queue
.EQU sys_mq_timedsend,                      276    @ send a message to a message queue
.EQU sys_mq_timedreceive,                   277    @ receive a message from a message queue
.EQU sys_mq_notify,                         278    @ register for notification when a message is available
.EQU sys_mq_getsetattr,                     279    @ get/set message queue attributes
.EQU sys_waitid,                            280    @ wait for a child process to change state
.EQU sys_socket,                            281    @ create an endpoint for communication
.EQU sys_bind,                              282    @ bind a name to a socket
.EQU sys_connect,                           283    @ initiate a connection on a socket
.EQU sys_listen,                            284    @ listen for connections on a socket
.EQU sys_accept,                            285    @ accept a connection on a socket
.EQU sys_getsockname,                       286    @ get socket name
.EQU sys_getpeername,                       287    @ get name of connected peer socket
.EQU sys_socketpair,                        288    @ create a pair of connected sockets
.EQU sys_send,                              289    @ send a message on a socket
.EQU sys_sendto,                            290    @ send a message on a socket
.EQU sys_recv,                              291    @ receive a message from a socket
.EQU sys_recvfrom,                          292    @ receive a message from a socket
.EQU sys_shutdown,                          293    @ shut down part of a full-duplex connection
.EQU sys_setsockopt,                        294    @ set options on sockets
.EQU sys_getsockopt,                        295    @ get options on sockets
.EQU sys_sendmsg,                           296    @ send a message on a socket using a message structure
.EQU sys_recvmsg,                           297    @ receive a message from a socket
.EQU sys_semop,                             298    @ System V semaphore operations
.EQU sys_semget,                            299    @ get a System V semaphore set identifier
.EQU sys_semctl,                            300    @ System V semaphore control operations
.EQU sys_msgsnd,                            301    @ XSI message send operation
.EQU sys_msgrcv,                            302    @ XSI message receive operation
.EQU sys_msgget,                            303    @ get a System V message queue identifier
.EQU sys_msgctl,                            304    @ System V message control operations
.EQU sys_shmat,                             305    @ XSI shared memory attach operation
.EQU sys_shmdt,                             306    @ XSI shared memory detach operation
.EQU sys_shmget,                            307    @ allocates a System V shared memory segment
.EQU sys_shmctl,                            308    @ System V shared memory control
.EQU sys_add_key,                           309    @ add a key to the kernel's key management facility
.EQU sys_request_key,                       310    @ request a key from the kernel's key management facility
.EQU sys_keyctl,                            311    @ manipulate the kernel's key management facility
.EQU sys_semtimedop,                        312    @ System V semaphore operations
.EQU sys_vserver,                           313    @ Unimplemented
.EQU sys_ioprio_set,                        314    @ set I/O scheduling class and priority
.EQU sys_ioprio_get,                        315    @ get I/O scheduling class and priority
.EQU sys_inotify_init,                      316    @ initialize an inotify instance
.EQU sys_inotify_add_watch,                 317    @ add a watch to an initialized inotify instance
.EQU sys_inotify_rm_watch,                  318    @ remove an existing watch from an inotify instance
.EQU sys_mbind,                             319    @ set memory policy for a memory range
.EQU sys_get_mempolicy,                     320    @ retrieve NUMA memory policy for a thread
.EQU sys_set_mempolicy,                     321    @ set default NUMA memory policy for a thread and its children
.EQU sys_openat,                            322    @ open file relative to directory file descriptor
.EQU sys_mkdirat,                           323    @ create a directory
.EQU sys_mknodat,                           324    @ create a special or ordinary file
.EQU sys_fchownat,                          325    @ change owner and group of a file relative to directory file descriptor
.EQU sys_futimesat,                         326    @ change timestamps of a file relative to a directory file descriptor
.EQU sys_fstatat64,                         327    @ get file status
.EQU sys_unlinkat,                          328    @ delete a name and possibly the file it refers to
.EQU sys_renameat,                          329    @ change the name or location of a file
.EQU sys_linkat,                            330    @ make a new name for a file
.EQU sys_symlinkat,                         331    @ make a new name for a file
.EQU sys_readlinkat,                        332    @ read value of a symbolic link
.EQU sys_fchmodat,                          333    @ change permissions of a file
.EQU sys_faccessat,                         334    @ determine accessibility of a file relative to directory file descriptor
.EQU sys_pselect6,                          335    @ synchronous I/O multiplexing
.EQU sys_ppoll,                             336    @ wait for some event on a file descriptor
.EQU sys_unshare,                           337    @ run program with some namespaces unshared from parent
.EQU sys_set_robust_list,                   338    @ set list of robust futexes
.EQU sys_get_robust_list,                   339    @ get list of robust futexes
.EQU sys_splice,                            340    @ splice data to/from a pipe
.EQU sys_arm_sync_file_range,               341    @ sync a file segment with disk
.EQU sys_tee,                               342    @ duplicating pipe content
.EQU sys_vmsplice,                          343    @ splice user pages to/from a pipe
.EQU sys_move_pages,                        344    @ move individual pages of a process to another node
.EQU sys_getcpu,                            345    @ determine CPU and NUMA node on which the calling thread is running
.EQU sys_epoll_pwait,                       346    @ wait  for  an I/O event on an epoll file descriptor
.EQU sys_kexec_load,                        347    @ load a new kernel for later execution
.EQU sys_utimensat,                         348    @ change file timestamps with nanosecond precision
.EQU sys_signalfd,                          349    @ create a file descriptor for accepting signals
.EQU sys_timerfd_create,                    350    @ timers that notify via file descriptors
.EQU sys_eventfd,                           351    @ create a file descriptor for event notification
.EQU sys_fallocate,                         352    @ manipulate file space
.EQU sys_timerfd_settime,                   353    @ timers that notify via file descriptors
.EQU sys_timerfd_gettime,                   354    @ timers that notify via file descriptors
.EQU sys_signalfd4,                         355    @ create a file descriptor for accepting signals
.EQU sys_eventfd2,                          356    @ create a file descriptor for event notification
.EQU sys_epoll_create1,                     357    @ open an epoll file descriptor
.EQU sys_dup3,                              358    @ duplicate a file descriptor
.EQU sys_pipe2,                             359    @ create pipe
.EQU sys_inotify_init1,                     360    @ initialize an inotify instance
.EQU sys_preadv,                            361    @ read data into multiple buffers
.EQU sys_pwritev,                           362    @ write data into multiple buffers
.EQU sys_rt_tgsigqueueinfo,                 363    @ queue a signal and data
.EQU sys_perf_event_open,                   364    @ set up performance monitoring
.EQU sys_recvmmsg,                          365    @ receive multiple messages on a socket
.EQU sys_accept4,                           366    @ accept a connection on a socket
.EQU sys_fanotify_init,                     367    @ create and initialize fanotify group
.EQU sys_fanotify_mark,                     368    @ add, remove, or modify an fanotify mark on a filesystem object
.EQU sys_prlimit64,                         369    @ get/set resource limits
.EQU sys_name_to_handle_at,                 370    @ obtain handle for a pathname
.EQU sys_open_by_handle_at,                 371    @ open file via a handle
.EQU sys_clock_adjtime,                     372    @ tune kernel clock
.EQU sys_syncfs,                            373    @ commit filesystem caches to disk
.EQU sys_sendmmsg,                          374    @ send multiple messages on a socket
.EQU sys_setns,                             375    @ reassociate thread with a namespace
.EQU sys_process_vm_readv,                  376    @ transfer data between process address spaces
.EQU sys_process_vm_writev,                 377    @ transfer data between process address spaces
.EQU sys_kcmp,                              378    @ compare  two  processes  to determine if they share a kernel resource
.EQU sys_finit_module,                      379    @ load a kernel module
.EQU sys_sched_setattr,                     380    @ set scheduling policy and attributes
.EQU sys_sched_getattr,                     381    @ get scheduling policy and attributes
.EQU sys_renameat2,                         382    @ change the name or location of a file
.EQU sys_seccomp,                           383    @ operate on Secure Computing state of the process
.EQU sys_getrandom,                         384    @ obtain a series of random bytes
.EQU sys_memfd_create,                      385    @ create an anonymous file
.EQU sys_bpf,                               386    @ perform a command on an extended BPF map or program
.EQU sys_execveat,                          387    @ execute program relative to a directory file descriptor
.EQU sys_userfaultfd,                       388    @ create  a file descriptor for handling page faults in user space
.EQU sys_membarrier,                        389    @ issue memory barriers on a set of threads
.EQU sys_mlock2,                            390    @ lock memory
.EQU sys_copy_file_range,                   391    @ Copy a range of data from one file to another
.EQU sys_preadv2,                           392    @ read data into multiple buffers
.EQU sys_pwritev2,                          393    @ write data into multiple buffers
.EQU sys_pkey_mprotect,                     394    @ set protection on a region of memory
.EQU sys_pkey_alloc,                        395    @ allocate a protection key
.EQU sys_pkey_free,                         396    @ free a protection key
.EQU sys_statx,                             397    @ get file status (extended)
.EQU sys_rseq,                              398    @ restartable sequences
makefile
PROJECT = flashpin26
MORESOURCE =
OBJS = $(PROJECT).o $(MORESOURCE)
ifdef DEBUG
	DEBUGFLGS = -g
else
	DEBUGFLGS =
endif
%.o : %-$(BITS).s
$(PROJECT): $(OBJS)
