So, I tried using the Astroprint plugin, but similar to Astroprint Plugin Install Issue issue, it didn't work. I have the same error. How do I fix?
Did you try the URL from the last comment in plugin manager > get more > ...from URL?
Yeah I tried that but, the same thing happened as before.
Please attach a systeminfo bundle to your next post.
Try this URL?
https://github.com/AstroPrint/OctoPrint-AstroPrint/archive/refs/heads/Update-python.zip
Thanks! It works!
Hello guys!
Just a small update from us (The Astroprint Team), we have published a new release of the plugin (1.7.0) in which issue is solved.
I already have it installed, but is there a way to update the plugin to the newest version? If so can you provide a link to it?
Yes, here it is the official page of the plugin -> AstroPrint Cloud
How to update it? One solution would be to uninstall the plugin and install it again. Also, Octoprint provide ways to update plugins (Software Update Plugin β OctoPrint master documentation )
technically using the zip link you used before you are basically on that version already. I don't see any other changes that were merged after that release, you are showing 1.7.0 for the plugin right?
Yes thats correct.
