I've tried installing the plugin multiple times with both the plugin manager and the terminal. When I install the plugin with the plugin manager in Octoprint, It shows a successful install but shows "Successfully Installed: Unknown" and then prompts to restart Octoprint. I restart it but the plugin is no where to be found. I am new to linux and Octoprint. Below is a copy of what it shows after installing with the plugin manager. Any help would be greatly appreciated. Thanks!
Update:
Also noticed that it is doing the same thing with the Filament Manager plugin.
When I put Octoprint into safe mode the astroprint plugin appears in the plugin manager. I disable it in safe mode and restart the server normally and again astroprint shows up in the plugin manager. I enable it and restart octoprint normally and its gone.
Installing plugin "AstroPrint Cloud" from https://github.com/AstroPrint/OctoPrint-AstroPrint/archive/master.zip...
/home/pi/OctoPrint/venv/bin/python3 -m pip --disable-pip-version-check install file:///tmp/tmp7vl1y6__/OctoPrint-AstroPrint-master.zip --no-cache-dir
Processing /tmp/tmp7vl1y6__/OctoPrint-AstroPrint-master.zip
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'done'
Requirement already satisfied: OctoPrint in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from AstroPrint==1.6.5) (1.9.0)
Requirement already satisfied: Pillow in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from AstroPrint==1.6.5) (9.5.0)
Requirement already satisfied: requests_toolbelt==0.8.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from AstroPrint==1.6.5) (0.8.0)
Requirement already satisfied: ws4py==0.3.4 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from AstroPrint==1.6.5) (0.3.4)
Requirement already satisfied: requests<3.0.0,>=2.0.1 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from requests_toolbelt==0.8.0->AstroPrint==1.6.5) (2.30.0)
Requirement already satisfied: OctoPrint-FileCheck>=2021.2.23 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (2021.2.23)
Requirement already satisfied: OctoPrint-FirmwareCheck>=2021.10.11 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (2021.10.11)
Requirement already satisfied: OctoPrint-PiSupport>=2022.6.13 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (2022.6.13)
Requirement already satisfied: argon2-cffi<22,>=21.3.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (21.3.0)
Requirement already satisfied: Babel<2.13,>=2.12.1 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (2.12.1)
Requirement already satisfied: cachelib<0.11,>=0.10.2 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (0.10.2)
Requirement already satisfied: Click<9,>=8.1.3 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (8.1.3)
Requirement already satisfied: colorlog<7,>=6.7.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (6.7.0)
Requirement already satisfied: emoji<3,>=2.2.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (2.4.0)
Requirement already satisfied: feedparser<7,>=6.0.10 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (6.0.10)
Requirement already satisfied: filetype<2,>=1.2.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (1.2.0)
Requirement already satisfied: Flask-Assets<3,>=2.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (2.0)
Requirement already satisfied: Flask-Babel<4,>=3.1.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (3.1.0)
Requirement already satisfied: Flask-Login<0.7,>=0.6.2 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (0.6.2)
Requirement already satisfied: Flask-Limiter<4,>=3.3.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (3.3.1)
Requirement already satisfied: flask<2.3,>=2.2.3 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (2.2.5)
Requirement already satisfied: frozendict<3,>=2.3.7 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (2.3.8)
Requirement already satisfied: future<1,>=0.18.3 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (0.18.3)
Requirement already satisfied: markdown<4,>=3.4.3 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (3.4.3)
Requirement already satisfied: netaddr<0.9,>=0.8 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (0.8.0)
Requirement already satisfied: netifaces<1,>=0.11 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (0.11.0)
Requirement already satisfied: passlib<2,>=1.7.4 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (1.7.4)
Requirement already satisfied: pathvalidate<3,>=2.5.2 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (2.5.2)
Requirement already satisfied: pkginfo<2,>=1.9.6 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (1.9.6)
Requirement already satisfied: psutil<6,>=5.9.4 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (5.9.5)
Requirement already satisfied: pydantic<2,>=1.10.7 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (1.10.8)
Requirement already satisfied: pylru<2,>=1.2.1 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (1.2.1)
Requirement already satisfied: pyserial<4,>=3.5 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (3.5)
Requirement already satisfied: PyYAML<6,>=5.4.1 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (5.4.1)
Requirement already satisfied: sarge==0.1.7.post1 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (0.1.7.post1)
Requirement already satisfied: semantic-version<3,>=2.10.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (2.10.0)
Requirement already satisfied: sentry-sdk<2,>=1.19.1 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (1.22.1)
Requirement already satisfied: tornado<7,>=6.2 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (6.3.1)
Requirement already satisfied: watchdog<3,>=2.3.1 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (2.3.1)
Requirement already satisfied: websocket-client<2,>=1.5.1 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (1.5.1)
Requirement already satisfied: werkzeug<2.3,>=2.2.3 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (2.2.3)
Requirement already satisfied: wrapt<1.16,>=1.15 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (1.15.0)
Requirement already satisfied: zeroconf==0.39.4 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (0.39.4)
Requirement already satisfied: zipstream-ng<2.0.0,>=1.5.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (1.5.0)
Requirement already satisfied: blinker<2,>=1.6.1 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (1.6.2)
Requirement already satisfied: class-doc<0.3,>=0.2.6 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (0.2.6)
Requirement already satisfied: regex in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (2023.5.5)
Requirement already satisfied: unidecode in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (1.3.6)
Requirement already satisfied: wheel in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from OctoPrint->AstroPrint==1.6.5) (0.40.0)
Requirement already satisfied: async-timeout>=4.0.1 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from zeroconf==0.39.4->OctoPrint->AstroPrint==1.6.5) (4.0.2)
Requirement already satisfied: ifaddr>=0.1.7 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from zeroconf==0.39.4->OctoPrint->AstroPrint==1.6.5) (0.2.0)
Requirement already satisfied: argon2-cffi-bindings in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from argon2-cffi<22,>=21.3.0->OctoPrint->AstroPrint==1.6.5) (21.2.0)
Requirement already satisfied: more-itertools>=5.0.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from class-doc<0.3,>=0.2.6->OctoPrint->AstroPrint==1.6.5) (9.1.0)
Requirement already satisfied: sgmllib3k in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from feedparser<7,>=6.0.10->OctoPrint->AstroPrint==1.6.5) (1.0.0)
Requirement already satisfied: Jinja2>=3.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from flask<2.3,>=2.2.3->OctoPrint->AstroPrint==1.6.5) (3.1.2)
Requirement already satisfied: itsdangerous>=2.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from flask<2.3,>=2.2.3->OctoPrint->AstroPrint==1.6.5) (2.1.2)
Requirement already satisfied: webassets>=2.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from Flask-Assets<3,>=2.0->OctoPrint->AstroPrint==1.6.5) (2.0)
Requirement already satisfied: pytz>=2022.7 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from Flask-Babel<4,>=3.1.0->OctoPrint->AstroPrint==1.6.5) (2023.3)
Requirement already satisfied: limits>=2.8 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from Flask-Limiter<4,>=3.3.0->OctoPrint->AstroPrint==1.6.5) (3.4.0)
Requirement already satisfied: ordered-set<5,>4 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from Flask-Limiter<4,>=3.3.0->OctoPrint->AstroPrint==1.6.5) (4.1.0)
Requirement already satisfied: rich<14,>=12 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from Flask-Limiter<4,>=3.3.0->OctoPrint->AstroPrint==1.6.5) (12.6.0)
Requirement already satisfied: typing-extensions>=4 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from Flask-Limiter<4,>=3.3.0->OctoPrint->AstroPrint==1.6.5) (4.5.0)
Requirement already satisfied: charset-normalizer<4,>=2 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from requests<3.0.0,>=2.0.1->requests_toolbelt==0.8.0->AstroPrint==1.6.5) (3.1.0)
Requirement already satisfied: idna<4,>=2.5 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from requests<3.0.0,>=2.0.1->requests_toolbelt==0.8.0->AstroPrint==1.6.5) (3.4)
Requirement already satisfied: urllib3<3,>=1.21.1 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from requests<3.0.0,>=2.0.1->requests_toolbelt==0.8.0->AstroPrint==1.6.5) (1.26.15)
Requirement already satisfied: certifi>=2017.4.17 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from requests<3.0.0,>=2.0.1->requests_toolbelt==0.8.0->AstroPrint==1.6.5) (2023.5.7)
Requirement already satisfied: MarkupSafe>=2.1.1 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from werkzeug<2.3,>=2.2.3->OctoPrint->AstroPrint==1.6.5) (2.1.2)
Requirement already satisfied: deprecated>=1.2 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from limits>=2.8->Flask-Limiter<4,>=3.3.0->OctoPrint->AstroPrint==1.6.5) (1.2.13)
Requirement already satisfied: importlib-resources>=1.3 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from limits>=2.8->Flask-Limiter<4,>=3.3.0->OctoPrint->AstroPrint==1.6.5) (5.12.0)
Requirement already satisfied: setuptools in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from limits>=2.8->Flask-Limiter<4,>=3.3.0->OctoPrint->AstroPrint==1.6.5) (59.6.0)
Requirement already satisfied: packaging<24,>=21 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from limits>=2.8->Flask-Limiter<4,>=3.3.0->OctoPrint->AstroPrint==1.6.5) (23.1)
Requirement already satisfied: commonmark<0.10.0,>=0.9.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from rich<14,>=12->Flask-Limiter<4,>=3.3.0->OctoPrint->AstroPrint==1.6.5) (0.9.1)
Requirement already satisfied: pygments<3.0.0,>=2.6.0 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from rich<14,>=12->Flask-Limiter<4,>=3.3.0->OctoPrint->AstroPrint==1.6.5) (2.15.1)
Requirement already satisfied: cffi>=1.0.1 in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from argon2-cffi-bindings->argon2-cffi<22,>=21.3.0->OctoPrint->AstroPrint==1.6.5) (1.15.1)
Requirement already satisfied: pycparser in /home/pi/OctoPrint/venv/lib/python3.10/site-packages (from cffi>=1.0.1->argon2-cffi-bindings->argon2-cffi<22,>=21.3.0->OctoPrint->AstroPrint==1.6.5) (2.21)
Building wheels for collected packages: AstroPrint
Building wheel for AstroPrint (setup.py): started
Building wheel for AstroPrint (setup.py): finished with status 'done'
Created wheel for AstroPrint: filename=AstroPrint-1.6.5-py3-none-any.whl size=98771 sha256=dac46d9c7c82d85048344f131b66509c77c65a01274e4e961c895c1dd056d708
Stored in directory: /tmp/pip-ephem-wheel-cache-cwtp02ot/wheels/c0/9c/77/974391d045578900faece5f368ceb4fb445515a2d4e102e72d
Successfully built AstroPrint
Installing collected packages: AstroPrint
Attempting uninstall: AstroPrint
Found existing installation: AstroPrint 1.6.5
Uninstalling AstroPrint-1.6.5:
Successfully uninstalled AstroPrint-1.6.5
Successfully installed AstroPrint-1.6.5
Done!
octoprint-systeminfo-20230527180559.zip (1.3 MB)
