Bambu A1 - Auth Token
I am trying to connect Octoprint to my Bambu A1.
The printer is connected to the internet but I can find the "Auth Code"...
Everytime I press log in, I receive an e-mail from Bambu with a verification code I can't find the Auth Code.
Where can I find it? I have no clue...
Thank you,
Screenshot 2025-01-24 at 00-07-26 OctoPrint
You need to be running the latest RC version of the plugin for the new auth flow via email, but I will be removing cloud mode completely plugin in the near future because of the recent firmware limitations being imposed by Bambu.
Thank you :slight_smile:
Also, I tested in LAN mode and works but controlling the nozzle in manual mode it can hit the bed hard...
Well, I can't control firmware's safety mechanisms, that should be something that the primer won't allow.
Also, keep in mind the plugin treats the printer as a virtual SD card essentially, so don't try sending prints that you've uploaded directly to OctoPrint or that aren't shown as stored on the SD card. Remove all the gcode scripts from OctoPrint's settings too.
hi just seen the response from bambu labs about the update they are adding a developer mode,
Yes, I've been watching that closely. The developer mode is basically the current implementation of local only mode.
Hi @jneilliii, I'm trying to Login but it doesn't seem to work anymore... Also I think I'm receiving a verification code by email, but I'm not sure how to input it to the Octoprint plugin...
Do you have an idea ? Thanks :slight_smile:
Email verification codes are in the RC version, switch the release channel in OctoPrint's software update settings and upgrade when prompted.
