Hi.
Need help.
The plugin "Bed Visualizer" test to close to the right edge of HeatBed, and missing 5-6 cm to test in left side. How can I change this ?
This would be a firmware settings for your probe offsets, etc. nothing to do with the Visualizer plugin.
Why. Then i send the Auot Level unit an G28 and G29 everything works fine, Only hvis plugin can't find out of it.
The plugin only sends the gcode commands you configure in settings, so it is the same as you typing those commands in terminal tab.
