Bed Visualizer plugin with Anycubic Predator
Anyone know how to get the bed visualizer to work with the Anycubic predator stock (dam proprietary firmware)?
If your printer's firmware does not have the ability to report its bed mesh in some format to the connected client it never will. Do you know what firmware their's is based on?
TriGorilla Pro
It has a touch level you attach after setting the Level via paper. After you attach the level it then doing a 37 point level.
And it's there a gcode command you can run to report the mesh points?
