I was wondering if there was a plug in or perhaps a basic setting in octoprint to keep the printer fans OFF until the bed/tool start to heat for a print job?
I don't think the fans would be needed until things get going. Is that correct?
Thank you,
Bob
searched plug in's but didn't see anything that would work
I don't own (and never will) any Creality products but I believe there are two (types of) fans on the Ender 3. One is a cold end fan and the other is a part cooling fan. The cold end fan on most 3D printers is an always on fan. The part cooling fan on most 3D printers is speed controlled using M106 and M107.
The part cooling fan can be off when the nozzle / bed are off. The cold end fan usually doesn't have any gcode commands to control it.
Most 3D printer firmware is able to start the cold end cooler fan at a certain temperature. Commonly used is 50Β°C.
It depends on the firmware adaptation if this feature is active.
Also, this will not work if the the cold end cooler fan is hard wired to the supply voltage.
It depends if the board has the support or not, as well. Most Creality boards do not, and specifically neither the 1.1.x nor 4.2.x board that come with the Ender 3 do, and the hotend fan is wired to be on anytime the board is powered.
Thanks everyone. I'll have to re-evaluate this. lol
