I am running OctoPrint on my Raspberry pi 4 and I was wondering if I can also install Node-Red to run in the background on the same pi.
I know how to do it using SSH I just want to make sure I won’t be messing anything up.
Hello @Omono35 !
Afaik, it is possible but not recommended.
If you are running a print job when you use Node Red and Node Red stalls the Pi, your print is broken.
