installed octolapse:
2023-02-14 06:39:09,677 > Building wheels for collected packages: Octolapse
2023-02-14 06:39:09,677 > Building wheel for Octolapse (setup.py): started
2023-02-14 06:39:37,237 > Building wheel for Octolapse (setup.py): finished with status 'done'
2023-02-14 06:39:37,238 > Created wheel for Octolapse: filename=Octolapse-0.4.1-cp310-cp310-linux_x86_64.whl size=3316781 sha256=d6269fa00b5defecba1be88fa762f8a573b039cc2edb8cca238f4577cf13f4e8
2023-02-14 06:39:37,238 > Stored in directory: /tmp/pip-ephem-wheel-cache-tw78273x/wheels/0c/86/08/c5f6ed65be337471c3fb68a69e0ecaa397e15d02f1b90b7000
2023-02-14 06:39:37,238 > Successfully built Octolapse
2023-02-14 06:39:37,238 > Installing collected packages: Octolapse
2023-02-14 06:39:37,740 > Successfully installed Octolapse-0.4.1
restart
| hardware:
| cores: 4
| freq: 3200.0
| ram: 3986964480
| os:
| bits: 64
| platform: linux
| python:
| pip: 22.3.1
| version: 3.10.6
| virtualenv: /home/flegge/OctoPrint/venv
2023-02-14 06:55:58,973 - octoprint.server - INFO - Reset webasset folder /home/flegge/.octoprint/generated/webassets...
2023-02-14 06:55:58,974 - octoprint.server - INFO - Reset webasset folder /home/flegge/.octoprint/generated/.webassets-cache...
2023-02-14 06:55:58,974 - octoprint.server - INFO - Reset webasset folder /home/flegge/.octoprint/generated/.webassets-manifest.json...
2023-02-14 06:55:59,982 - octoprint.server.util.flask.collect_plugin_assets - WARNING - Plugin simpleemergencystop is referring to non existing css asset css/fontawesome.all.min.css
2023-02-14 06:56:00,363 - octoprint.plugins.DisplayLayerProgress - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2023-02-14 06:56:00,363 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin DisplayLayerProgress is DISABLED
2023-02-14 06:56:00,364 - octoprint.plugins.SpoolManager - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2023-02-14 06:56:00,364 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin SpoolManager is DISABLED
2023-02-14 06:56:00,365 - octoprint.plugins.bedlevelvisualizer - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2023-02-14 06:56:00,365 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin bedlevelvisualizer is DISABLED
2023-02-14 06:56:00,365 - octoprint.plugins.firmwareupdater - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2023-02-14 06:56:00,365 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin firmwareupdater is DISABLED
2023-02-14 06:56:00,366 - octoprint.plugins.octolapse - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2023-02-14 06:56:00,366 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin octolapse is DISABLED
2023-02-14 06:56:00,367 - octoprint.plugins.uicustomizer - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2023-02-14 06:56:00,367 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin uicustomizer is DISABLED
2023-02-14 06:56:00,757 - octoprint.plugins.firmwareupdater - INFO - Setting maximum upload size for /flash to 5243904
2023-02-14 06:56:00,757 - octoprint.server - INFO - Shutting down intermediary server...
2023-02-14 06:56:00,834 - octoprint.server - INFO - Intermediary server shut down
2023-02-14 06:56:00,836 - octoprint.events - INFO - Processing startup event, this is our first event
2023-02-14 06:56:00,837 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2023-02-14 06:56:00,838 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2023-02-14 06:56:00,839 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2023-02-14 06:56:00,849 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2023-02-14 06:56:00,861 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2023-02-14 06:56:00,879 - octoprint.server - INFO - Trying to connect to configured serial port /dev/ttyACM0
2023-02-14 06:56:00,934 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2023-02-14 06:56:00,936 - octoprint.util.comm - INFO - Connecting to port /dev/ttyACM0, baudrate 115200
2023-02-14 06:56:00,949 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2023-02-14 06:56:00,953 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2023-02-14 06:56:00,967 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2023-02-14 06:56:01,008 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2023-02-14 06:56:01,022 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-02-14 06:56:01,065 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-02-14 06:56:01,084 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2023-02-14 06:56:01,183 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-02-14 06:56:01,199 - octoprint.plugins.firmwareupdater - INFO - Got CONNECTED event
2023-02-14 06:56:01,200 - octoprint.plugins.firmwareupdater - INFO - Run postflash flag is not set
2023-02-14 06:56:01,230 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin bugfix-2.0.x (May 28 2022 19:03:55)"
2023-02-14 06:56:01,346 - octoprint.plugins.firmware_check - INFO - Your printer's firmware is a development build of Marlin (build date 20220528). It might be more unstable than a release version and should be kept up-to-date.. More information at https://faq.octoprint.org/warning-firmware-development
2023-02-14 06:56:01,351 - octoprint.plugins.firmwareupdater - INFO - Setting BINARY_FILE_TRANSFER capability to False
2023-02-14 06:56:01,376 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2023-02-14 06:56:01,423 - octoprint.util.comm - INFO - Firmware states that it supports emergency GCODEs to be sent without waiting for an acknowledgement first
2023-02-14 06:56:01,426 - octoprint.plugins.firmware_check - INFO - Your printer's firmware supports host action commands, but they are disabled. The firmware will not inform OctoPrint about job pause & cancellations, filament runouts, and similar firmware-side events. If you want this functionality, you need to change your firmware's configuration.. More information at https://faq.octoprint.org/warning-firmware-hostcommands
2023-02-14 06:56:01,507 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2023-02-14 06:56:01,556 - octoprint.plugins.SpoolManager - INFO - Send Event 'plugin_spoolmanager_spool_selected' with payload '{'toolId': 0, 'databaseId': 1, 'spoolName': 'ClaesO Red#1', 'material': 'PLA', 'colorName': 'red', 'remainingWeight': 350.7370621850075}' to event-bus
2023-02-14 06:56:01,568 - octoprint.plugin - ERROR - Error while calling plugin octolapse
File "/home/flegge/OctoPrint/venv/lib/python3.10/site-packages/octoprint/plugin/__init__.py", line 273, in call_plugin
File "/home/flegge/OctoPrint/venv/lib/python3.10/site-packages/octoprint/util/__init__.py", line 1688, in wrapper
return f(*args, **kwargs)
File "/home/flegge/OctoPrint/venv/lib/python3.10/site-packages/octoprint_octolapse/__init__.py", line 2362, in on_startup
raise e
File "/home/flegge/OctoPrint/venv/lib/python3.10/site-packages/octoprint_octolapse/__init__.py", line 2311, in on_startup
self.load_settings()
File "/home/flegge/OctoPrint/venv/lib/python3.10/site-packages/octoprint_octolapse/__init__.py", line 1999, in load_settings
new_settings, defaults_loaded = OctolapseSettings.load(
File "/home/flegge/OctoPrint/venv/lib/python3.10/site-packages/octoprint_octolapse/settings.py", line 2406, in load
new_settings = OctolapseSettings.create_from_iterable(
File "/home/flegge/OctoPrint/venv/lib/python3.10/site-packages/octoprint_octolapse/settings.py", line 2528, in create_from_iterable
new_object.update(iterable)
File "/home/flegge/OctoPrint/venv/lib/python3.10/site-packages/octoprint_octolapse/settings.py", line 108, in update
Settings._update(self, iterable)
File "/home/flegge/OctoPrint/venv/lib/python3.10/site-packages/octoprint_octolapse/settings.py", line 116, in _update
if not isinstance(iterable, collections.Iterable):
AttributeError: module 'collections' has no attribute 'Iterable'
get load erro: Settings Load Error
Octolapse was unable to load the current settings. Status: error. Error: INTERNAL SERVER ERROR
Maybe due to the lack of 'printer profile' in plugin but when I try to add nothing happens.
any ideas, I am new to Linux (Ubuntu) so any tip or advise would be much apriciated.
BR FF
