"You can modify them either through the plugin’s configuration dialog under Settings, or by directly editing", I know I'm missing something but I don't see a config menu item for the bundled plugin Action Command Prompt Support.
I might have removed that again (because this should no longer actually need configuration and people were messing around with it regardless and breaking things left and right) but forgot to adjust the docs.
I think the names might have changed - they are called 'Printer Dialogs' (action command prompt support) and 'Printer Notifications' (action command notifications support). Old names were too long to be useful.
Ah. Thanks for jogging my memory there, THAT was what changed.
Thanks very much
