I'm a noob to writing octoprint plugins (but have programming experience) and working on my first plugin, which is a pretty simple one that monitors the printer temperature and heats it up if it gets below a certain value to prevent a MINTEMP error.
However, I can't for the life of me get my settings to show up on the plugin settings page. It does create a settings page for my plugin and displays a label and text entry box, but it does not pull the settings value into it (i.e. text is always blank). Also, the "Saving" button has a permanent spinner on it and cannot be clicked. My understanding is that this means there's something wrong with the way I have my settings setup.
BTW. My .jinja2 file doesn't get picked up automatically. I have to include an explicit template="PreventMINTEMP_settings.jinja2" in my get_template_configs. Note sure if this means anything or if there's some case-sensitivity going on here.
Would really appreciate your help.
Here's my init.py file:
import octoprint.plugin
import octoprint.util
import octoprint.printer
heating = False
class PreventmintempPlugin(octoprint.plugin.StartupPlugin,
octoprint.plugin.SettingsPlugin,
octoprint.plugin.TemplatePlugin
def check_temp(self):
#global count
heat_thresh = 10.0 #settings.preventMINTEMP.heat_thresh
ignore_thresh = -10.0 #settings.preventMINTEMP.ignore_thresh
heat_target = 30.0 #settings.preventMINTEMP.heat_target
global heating
#count += 1
print("Checking temperature")
pstate = self._printer.get_state_id()
if(pstate != "PRINTING"): #Don't do monitoring if we're printing
tdict = self._printer.get_current_temperatures()
all_at_target = True
for x in tdict:
#print(x, ": ", tdict[x])
if(x[:4] == "tool" or x == "bed"):
elt_name = x
T = tdict[x]["actual"]
Ttarg = tdict[x]["target"]
if(Ttarg == 0 and T > ignore_thresh and T < heat_thresh):
print(f"Element {x} is below {heat_thresh}C temperature threshold. Heating element",x)
all_at_target = False
heating = True
self._printer.set_temperature(elt_name,heat_target)
else:
# If we're heating this element and we reached target, then turn it off
if(Ttarg != 0.0 and (T >= heat_target or T < ignore_thresh)):
if(T > ignore_thresh):
print(f"Element {elt_name} reached {heat_target}C target. Turning off heater.")
else:
print(f"Element {elt_name} is below error temperature.")
self._printer.set_temperature(elt_name, 0.0)
elif(Ttarg != 0.0):
if(all_at_target and heating):
print("All elements above temperature target.")
heating = False
else:
print("Printer is printing")
def on_after_startup(self):
check_period = 5.0 #settings.plugins.PreventMINTEMP.check_period
self._logger.info("Prevent MINTEMP started!")
print("Prevent MINTEMP started...")
t = octoprint.util.RepeatedTimer(check_period,self.check_temp)
t.start()
##~~ SettingsPlugin mixin
def get_settings_defaults(self):
return {
'heat_thresh': 15.0, #lower temperature threshold to start heating
'ignore_thresh': -10.0, #temperature below which we are in MINTEMP error, so will not heat
'heat_target': 30.0, #target temperture to which to heat elements
'check_period': 5.0 #how often to check temperature in seconds
def get_template_configs(self):
return [
dict(type="settings", template="PreventMINTEMP_settings.jinja2", custom_bindings=False)
# If you want your plugin to be registered within OctoPrint under a different name than what you defined in setup.py
# ("OctoPrint-PluginSkeleton"), you may define that here. Same goes for the other metadata derived from setup.py that
# can be overwritten via __plugin_xyz__ control properties. See the documentation for that.
__plugin_name__ = "Prevent MINTEMP"
# Set the Python version your plugin is compatible with below. Recommended is Python 3 only for all new plugins.
# OctoPrint 1.4.0 - 1.7.x run under both Python 3 and the end-of-life Python 2.
# OctoPrint 1.8.0 onwards only supports Python 3.
__plugin_pythoncompat__ = ">=3,<4" # Only Python 3
def __plugin_load__():
global __plugin_implementation__
__plugin_implementation__ = PreventmintempPlugin()
# global __plugin_hooks__
# __plugin_hooks__ = {
# "octoprint.plugin.softwareupdate.check_config": __plugin_implementation__.get_update_information
and here's my preventMINTEMP
<form class="form-horizontal">
<div class="control-group">
<label class="control-label">{{ _('Heating Threshold') }}</label>
<div class="controls">
<input type="text" class="input-block-level" data-bind="value: settings.plugins.PreventMinTEMP.heat_thresh">
</div>
</div>
</form>
