Can't load stl into octoprint
Cura 4.8
When I try to print a model sliced in Cura, I get the following message...
Octolapse Startup Failed
Slicer Settings Missing*
Some slicer settings were missing from your gcode file. Missing Settings: Retraction Length,Retraction
Speed,Deretraction Speed,Z Lift Height,X/Y Travel Speed,Z Travel Speed
This only happens with the Cura Slice. The PrusaSlice works fine. I've tried finding and making sure there was a value in each of the settings that Seem to coorespond to the settings in the error message, but it makes no difference, no matter what I put it. Maybe I have the wrong settings.
Log:
2021-01-14 02:17:23,030 - octolapse.init - INFO - Started logging to file.
2021-01-14 02:17:23,033 - octolapse.settings - INFO - Loading existing settings file from: /home/pi/.octoprint/data/octolapse/settings.json.
2021-01-14 02:17:23,069 - octolapse.settings - INFO - Creating settings from iterable.
2021-01-14 02:17:23,131 - octolapse.settings - INFO - Settings created from iterable.
2021-01-14 02:17:23,131 - octolapse.settings - INFO - Settings file loaded.
2021-01-14 22:17:47,547 - octolapse.init - ERROR - Some slicer settings were missing from your gcode file. Missing Settings: Retraction Length,Retraction Speed,Deretraction Speed,Z Lift Height,X/Y Travel Speed,Z Travel Speed
2021-01-14 22:20:00,510 - octolapse.init - INFO - Started logging to file.
2021-01-14 22:20:00,522 - octolapse.settings - INFO - Loading existing settings file from: /home/pi/.octoprint/data/octolapse/settings.json.
2021-01-14 22:20:00,687 - octolapse.settings - INFO - Creating settings from iterable.
2021-01-14 22:20:01,253 - octolapse.settings - INFO - Settings created from iterable.
2021-01-14 22:20:01,255 - octolapse.settings - INFO - Settings file loaded.
2021-01-14 22:21:41,665 - octolapse.init - ERROR - Some slicer settings were missing from your gcode file. Missing Settings: Retraction Length,Retraction Speed,Deretraction Speed,Z Lift Height,X/Y Travel Speed,Z Travel Speed
2021-01-14 22:17:24,517 - octolapse.init - INFO - Started logging to file.
2021-01-14 22:17:24,521 - octolapse.settings - INFO - Loading existing settings file from: /home/pi/.octoprint/data/octolapse/settings.json.
2021-01-14 22:17:24,558 - octolapse.settings - INFO - Creating settings from iterable.
2021-01-14 22:17:24,620 - octolapse.settings - INFO - Settings created from iterable.
2021-01-14 22:17:24,621 - octolapse.settings - INFO - Settings file loaded.
2021-01-15 15:57:54,043 - octolapse.init - ERROR - Some slicer settings were missing from your gcode file. Missing Settings: Retraction Length,Retraction Speed,Deretraction Speed,Z Lift Height,X/Y Travel Speed,Z Travel Speed
2021-01-15 15:58:30,994 - octolapse.init - ERROR - Some slicer settings were missing from your gcode file. Missing Settings: Retraction Length,Retraction Speed,Deretraction Speed,Z Lift Height,X/Y Travel Speed,Z Travel Speed
2021-01-15 16:10:22,628 - octolapse.init - ERROR - Some slicer settings were missing from your gcode file. Missing Settings: Retraction Length,Retraction Speed,Deretraction Speed,Z Lift Height,X/Y Travel Speed,Z Travel Speed
Anything that will help me understand what I need to do would be greatly appriciated.
Pi version, printer, firmware...)
Try to upload the gcode to OctoPrint
I assume you mean fro the SD. I will do that, but have an unrelated problem that requires a part that I won't get until next week. I will try it as soon as I can.
Sounds like a problem specific to Octolapse, moved there
