Thanks.
I'm going to reinstall anyway from scratch on new hardware.
But am super curious what gives here and want to learn from it.
Meanwhile If I want to print I simply re-install the old version and it works perfectly.
Steve
Thanks.
Steve
Any way to "clear this out"?
If it's still looking for the wrong files where is the location where it's configured to look for something so I can check it there or replace this configuration file?
This path makes me believe that you have manually installed octoprint outside of a virtualenv. The quick approach would be to just install from scratch using a virtualenv, as recommended by the raspbian install guide (raspbian is based on debian so the instructions are the same).
Thanks,
Will check it out.
