Is it possible to combine multiple plugins? For example catch an event of a filament runout plugin and then use the pushover plugin too send a notification.
out of the box there is no "communication-path" between plugins.
My DisplayLayerProgress-Plugin (DLP) e.g. provides data and a lot of other Plugins consume this data in different ways. E.g. "Dashboard-Plugin" listen on the internal OP Eventbus or "OctoPod" is using a web-socket interface.
So, this plugin provides several data-provider interfaces (eventbus, websocket, rest-api).
On the other hand my PrintJobHistory-Plugin is a data consumer. It collects data from DLP, PreHeat,...and a lot of other plugin.
Here you need to contact the "Provider-Plugin" Author to define an interface (e.g. eventbus naming/structure) or (more risky) just grab the plugin implementation and read the fields.
pluginInfo = self._getPluginInformation("preheat")
self._preHeatPluginImplementationState = pluginInfo[0]
self._preHeatPluginImplementation = pluginInfo[1]
neededValue = self._preHeatPluginImplementation.neededValue
# get the plugin with status information
# [0] == status-string
# [1] == implementaiton of the plugin
def _getPluginInformation(self, pluginKey):
status = None
implementation = None
if pluginKey in self._plugin_manager.plugins:
plugin = self._plugin_manager.plugins[pluginKey]
if plugin != None:
if (plugin.enabled == True):
status = "enabled"
# for OP 1.4.x we need to check agains "incompatible"-attribute
if (hasattr(plugin, 'incompatible') ):
if (plugin.incompatible == False):
implementation = plugin.implementation
else:
status = "incompatible"
else:
# OP 1.3.x
pass
else:
status = "disabled"
else:
status = "missing"
return [status, implementation]
Thanks for the reply, I tried it and yes I can get values from other plugins. But then I still need to write the logica in my own plugin, and I don't want that.
The Filament-Reloaded plugin has an API endpoint which I can poll that. Is that an acceptable solution? I don't know.
It would be perfect if the Filament-Reloaded could throw an event which my plugins listens for, I think self._plugin_manager.send_plugin_message( will do just that. I am going too try that.
API endpoints are completely acceptable options. They are in my power plugins and other systems are hooking into them. But in your case, yes an eventbus driven integration would probably be preferred because the send_plugin_message I believe will only work when a web browser is open to the OctoPrint web interface.
Make a patch for using the eventbus!
Something like this:
Patch
def sensor_callback(self, _):
if self.no_filament():
eventManager().fire("Filament-Reloaded-Sensor-Status", "no filament")
else:
eventManager().fire("Filament-Reloaded-Sensor-Status", "filament detected")
And in your plugin you can use the on_event Methode or you subscribe to a above event:
eventmanager.subscribe("Filament-Reloaded-Sensor-Status", self._myEventListener)
or
def on_event(self, event, payload):
if event == ""Filament-Reloaded-Sensor-Status"":
## do something usefull
As @jneilliii already mentioned send_plugin_message method could only be used, if you want to exchange data from one plugin to an other via the browser-session.
You should try to integrate the most popular/recently updated plugin to submit your changes to. As you mentioned some of those plugin authors have gone ghost.
