Servus,
We would like to manage the global configurations of our Octoprint instances via Git.
We want to use a master branch in git. From this branch each Octoprint instance pulls and then does a rebase to merge the local information with the global information.
Therefore we need to embed the individual local settings in a comment block. Otherwise the rebase will not work automatically.
Unfortunately the comments disappear in the config.yaml file after restarting or changing settings. Comments are added according to the Ocotprint manual.
Attached is the excerpt from a config file.
server:
commands:
serverRestartCommand: sudo service octoprint restart
systemRestartCommand: sudo shutdown -r now
systemShutdownCommand: sudo shutdown -h now
# PROTECTED
firstRun: true
# PROTECTED
onlineCheck:
enabled: true
pluginBlacklist:
enabled: true
# PROTECTED
secretKey: "no default value"
# PROTECTED
seenWizards:
corewizard: 3
telegram: 1
tracking: null
temperature:
profiles:
- bed: 100
chamber: null
extruder: 210
- bed: 60
chamber: null
extruder: 180
webcam:
ffmpeg: /usr/bin/ffmpeg
flipH: true
flipV: true
snapshot: http://127.0.0.1:8080/?action=snapshot
stream: /webcam/?action=stream
What would be the correct procedure so that the comments in the config file are not deleted?
Thanks for your help
