Do you know if it’s possible to use octoprint with the new anycubic kobra 2 neo ?
It is easy to use the Kobra 2 Neo with octoprint. Only thing that if you connect the usb you cant anymore use the onboard LCD to command the printer. You have to use the octoprint webpage from your raspberry to control the printer (e.g. select objects ti print). What also does not work is the Filament extrude and retract commands from the octoprint webpage. The command seems to do nothing in my setup. But i am a newbie on this issue and on 3d printing in general. Therefore i would say it is really easy to get the printer to work.
Normal printing used to work out of the box.
How do I change the motor values for kobra 2 neo
which values do you mean?
If you move the cursor on the lcd screen to settings as soon as it comes on you can still control the settings of the printer (filament change been one) even when using Octoprint. Just don't come out of the settings screen or it will lock you out again until you reboot the printer.
Interesting hack.
