Connection to printer prusa MK3S
Octopi cannot connect to the printer
no
Complete Logs
Dec 18 14:15:58 octopi MJPG-streamer [817]: starting application
Dec 18 14:15:58 octopi MJPG-streamer [817]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
Dec 18 14:15:58 octopi MJPG-streamer [817]: Using V4L2 device.: /dev/video10
Dec 18 14:15:58 octopi MJPG-streamer [817]: Desired Resolution: 640 x 480
Dec 18 14:15:58 octopi MJPG-streamer [817]: Frames Per Second.: 10
Dec 18 14:15:58 octopi MJPG-streamer [817]: Format............: JPEG
Dec 18 14:15:58 octopi MJPG-streamer [817]: TV-Norm...........: DEFAULT
Dec 18 14:15:58 octopi MJPG-streamer [817]: init_VideoIn failed
Dec 18 15:44:44 octopi kernel: [ 1224.641433] printk: systemd: 33 output lines suppressed due to ratelimiting
Dec 18 15:48:11 octopi kernel: [ 1430.758626] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
Dec 18 15:55:53 octopi kernel: [ 1893.338881] usb 1-1.2: USB disconnect, device number 4
Dec 18 15:55:58 octopi kernel: [ 1897.730144] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
Dec 18 15:55:58 octopi kernel: [ 1897.877220] usb 1-1.3: New USB device found, idVendor=2c99, idProduct=0002, bcdDevice= 1.30
Dec 18 15:55:58 octopi kernel: [ 1897.877254] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 18 15:55:58 octopi kernel: [ 1897.877275] usb 1-1.3: Product: Original Prusa i3 MK3
Dec 18 15:55:58 octopi kernel: [ 1897.877294] usb 1-1.3: Manufacturer: Prusa Research (prusa3d.com)
Dec 18 15:55:58 octopi kernel: [ 1897.877314] usb 1-1.3: SerialNumber: CZPX3720X004XK16148
Dec 18 15:55:58 octopi kernel: [ 1897.895542] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Dec 18 15:55:58 octopi mtp-probe: checking bus 1, device 5: "/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.3"
Dec 18 15:55:58 octopi mtp-probe: bus: 1, device: 5 was not an MTP device
<small>`octoprint.log`, `serial.log` or output on terminal tab *at a minimum*, browser error console if UI issue ... **no logs, no support!** Not log excerpts, *complete* logs.)</small>
Changing monitoring state from "Offline" to "Detecting serial connection"
Performing autodetection with 7 port/baudrate candidates: /dev/ttyACM0@115200, /dev/ttyACM0@250000, /dev/ttyACM0@230400, /dev/ttyACM0@57600, /dev/ttyACM0@38400, /dev/ttyACM0@19200, /dev/ttyACM0@9600
Trying port /dev/ttyACM0, baudrate 115200
Connecting to port /dev/ttyACM0, baudrate 115200
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0xac0fd050, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0*125
Recv: Command not found!
Handshake attempt #2 with timeout 2.0s
Handshake attempt #3 with timeout 2.0s
Trying port /dev/ttyACM0, baudrate 250000
Trying port /dev/ttyACM0, baudrate 230400
Trying port /dev/ttyACM0, baudrate 57600
Trying port /dev/ttyACM0, baudrate 38400
Trying port /dev/ttyACM0, baudrate 19200
Trying port /dev/ttyACM0, baudrate 9600
Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
Connected to: Serial<id=0xa82064f0, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Connected to: Serial<id=0xb2d44ef0, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Connected to: Serial<id=0xafb1eb90, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Recv: Ý\x89J\x88\x13\x8b\x00¹\x10\x9dB\x08+!\x00\x00\x11\x01\x83µÅ¸ØÖ\x9b½n\x9b×qS\x00\x80ù\x9b¨
WARNThe received line contains at least one null byte character at position 6, this hints at some data corruption going on
Recv: ±Í\x83\x012Fhù
Connected to: Serial<id=0xb2d3f810, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
### Additional information about your setup
<small>OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ... **as much data as possible**</small>
browser.user_agent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36
connectivity.connection_check: 1.1.1.1:53
connectivity.connection_ok: true
connectivity.enabled: true
connectivity.online: true
connectivity.resolution_ok: true
env.hardware.cores: 1
env.hardware.freq: 700
env.hardware.ram: 386256896
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.model: Raspberry Pi Model B Rev 2
env.plugins.pi_support.octopi_version: 0.17.0
env.plugins.pi_support.throttle_state: 0x0
env.python.pip: 19.3.1
env.python.version: 2.7.16
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.2
The problem has now been solved:
Serial connection: /dev/ttyACM0
Baud rate 115200
A connection is successfully established with these parameters.
No connection can be established with AUTO parameters.
Hello @Dirk_Soetebeer !
Great you found it!
So could you please:
