I'd like to suggest a consolidated Temperature and Control screen, or at a minimum, adding the Temperature controls at the bottom of the Control screen.
There's just no benefit to having to switch tabs to pre-heat and then move the printer if need be before starting a print.
You certainly can just fire off a print and slicer settings will pre-heat, but I like to kick off my print and know it's starting to get check on it.
Didn't see a best place for recommendations, so let me know if I should submit this elsewhere on the forum.
Thanks for considering.
Big fan of 3rd party Octo4a and wishing someone would start a Wiki of compatible phones and tablets and charger adapters to locate combinations that will work, charge, and see the printer.
I can contribute two:
- Blackview A9 Pro, Works reliably, charges and sees printer
- 2020 8" Fire Tablet, won't charge and see printer, but battery life of around 10 hours makes it usable for prints under that duration
