I have a project idea, and I'm wondering if octoprint would be a good way to implement it.
I have a monoprice select mini printer that I want to try to re purpose to make mini punch needle rugs.
(would be a similar process as turning a 3d printer into a plotter and I'd generate custom gcode based on a design)
My main issue is that the punch needle needs to be rotated as you go. Would it be possible to create an octoprint plugin to control an extra motor with the pi alongside the 3d printer to turn the needle at specific times? Or is there a better way to go about this. Thanks!
