For PrusaSlicer does not support a fan on a second extruder, I started to create a plugin that copies the M106 value to the second fan.
I started with this: Plugin-Examples/rewrite_m107.py at 48316b8a5257763966d0c6c0a2f57a4825bb1db1 · OctoPrint/Plugin-Examples · GitHub
And now I am here:
# coding=utf-8
import octoprint.plugin
class CopyM106Plugin(octoprint.plugin.OctoPrintPlugin):
def copy_m106(self, comm_instance, phase, cmd, cmd_type, gcode, *args, **kwargs):
if gcode and gcode == "M106":
# global cmd_copy_m106
cmd_copy_m106 = cmd
cmd_copy_m106 = cmd_copy_m106[5:]
self._logger.info(cmd_copy_m106)
return [("M106 "+ cmd_copy_m106),
("M106 P1 " + cmd_copy_m106)]
__plugin_name__ = "Copy M106"
__plugin_pythoncompat__ = ">=2.7,<4"
def __plugin_load__():
global __plugin_implementation__
__plugin_implementation__ = CopyM106Plugin()
global __plugin_hooks__
__plugin_hooks__ = {
"octoprint.comm.protocol.gcode.queuing": __plugin_implementation__.copy_m106,
So far it works well on the virtual printer:
2021-04-08 18:50:29,781 - Changing monitoring state from "Operational" to "Starting"
2021-04-08 18:50:30,451 - Send: N1 M106 S0*102
2021-04-08 18:50:30,473 - Recv: ok
2021-04-08 18:50:30,479 - Send: N2 M106 P1 S0*36
2021-04-08 18:50:30,489 - Recv: ok
2021-04-08 18:50:30,494 - Changing monitoring state from "Starting" to "Printing"
2021-04-08 18:50:30,580 - Send: N3 M106 S10*85
2021-04-08 18:50:30,588 - Recv: ok
2021-04-08 18:50:30,590 - Send: N4 M106 P1 S10*19
2021-04-08 18:50:30,595 - Recv: ok
2021-04-08 18:50:30,654 - Send: N5 M106 S255*96
2021-04-08 18:50:30,661 - Recv: ok
2021-04-08 18:50:30,663 - Send: N6 M106 P1 S255*34
2021-04-08 18:50:30,668 - Recv: ok
2021-04-08 18:50:30,727 - Send: N7 M106 S0*96
2021-04-08 18:50:30,734 - Recv: ok
2021-04-08 18:50:30,736 - Send: N8 M106 P1 S0*46
2021-04-08 18:50:30,741 - Recv: ok
2021-04-08 18:50:30,813 - Changing monitoring state from "Printing" to "Finishing"
2021-04-08 18:50:31,741 - Recv: wait
2021-04-08 18:50:32,741 - Recv: wait
2021-04-08 18:50:33,744 - Recv: wait
2021-04-08 18:50:34,746 - Recv: wait
2021-04-08 18:50:35,746 - Recv: wait
2021-04-08 18:50:35,840 - Changing monitoring state from "Finishing" to "Operational"
But in octoprint.log I get the annoying UnboundLocalError:
2021-04-08 18:48:50,855 - octoprint.util.comm - ERROR - Error while processing hook M106_Copy for phase queuing and command M110 N0:
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/comm.py", line 4509, in _process_command_phase
tags=tags,
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/__init__.py", line 1941, in wrapper
return f(*args, **kwargs)
File "/home/pi/.octoprint/plugins/M106_Copy.py", line 12, in copy_m106
UnboundLocalError: local variable 'cmd_copy_m106' referenced before assignment
2021-04-08 18:48:51,018 - octoprint.filemanager.analysis - INFO - Starting analysis of local:Test.gcode
2021-04-08 18:48:51,022 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.01 --throttle-lines=100 --bed-z=0.0 --offset 0.0 0.0 /home/pi/.octoprint/uploads/Test.gcode
2021-04-08 18:48:51,224 - octoprint.util.comm - ERROR - Error while processing hook M106_Copy for phase queuing and command M110 N0:
tags=tags,
I set the variable cmd_copy_m106 to global, but that resulted in keeping the variable to the first truncated value (S0)
Any ideas?
