Hello,
I'm a newbie and I spent 3 days on this problem, triying to make a button to trigger a click event and process it in __init__.py. I read the refererece for the functions and also spent a lot of time reading sources on GitHub. No success !
Here's what I'm doing :
in the jinja file (among other data controls that all work fine) :
<div class="control-group">
<div class="controls">
<button class="btn" data-bind="click: test"> {{ _('Test') }} </button>
</div>
</div>
in the js file :
$(function () {
function marlinmodeViewModel(parameters) {
var self = this;
self.test = function (data) {
OctoPrint.simpleApiCommand("marlinmode", "testMessage");
OCTOPRINT_VIEWMODELS.push({
construct: marlinmodeViewModel,
dependencies: ["settingsViewModel"],
elements: ["#settings_plugin_marlinmode"]
and in __init__.py :
# -*- coding: utf-8 -*-
from __future__ import absolute_import, unicode_literals
import octoprint.plugin
import logging
import flask
TOP_LEFT = 0
TOP_CENTER = 1
TOP_RIGHT = 2
CENTER_LEFT = 3
CENTER_CENTER = 4
CENTER_RIGHT = 5
BOTTOM_LEFT = 6
BOTTOM_CENTER = 7
BOTTOM_RIGHT = 8
class MarlinModePlugin(octoprint.plugin.StartupPlugin,
octoprint.plugin.TemplatePlugin,
octoprint.plugin.AssetPlugin,
octoprint.plugin.SimpleApiPlugin,
octoprint.plugin.SettingsPlugin):
def on_after_startup(self):
self._logger.info("********************* on_after_startup() *******************")
def get_settings_defaults(self):
self._logger.info("******************** get_settings_defaults() *******************")
return dict(
full_screen = "true",
size = 50,
alignment = CENTER_CENTER,
viewport_opacity = 100,
fgnd_color = "#ffffff", # white
fgnd_opacity = 100,
bkgnd_color = "#0000ff", # blue
bkgnd_opacity = 100,
spi_speed = 8,
debounce_time = 300,
show_at_boot = "true",
dtovl_shtdn = "true",
disable_HID = "true"
def __init__(self):
self.dummy=0
def get_template_configs(self):
return [
dict(type="settings", custom_bindings=False)
def get_api_commands(self):
return dict(
testMessage = []
def on_api_command(self, command, data):
if command == "testMessage":
self._logger.info("****************** !!!!!!!!!!!! testMessage !!!!!!!!!!!!!!!!! *******************")
def get_assets(self):
return dict(
js=["js/marlinmode.js"],
__plugin_name__ = "Marlin Mode"
__plugin_version__ = "1.0.0"
__plugin_description__ = "Marlin Mode service Configurator"
__plugin_pythoncompat__ = ">=2.7,<4"
__plugin_implementation__ = MarlinModePlugin()
I always get this error in the Firefox console :
Could not bind view model SettingsViewModel to target #settings_dialog : click@http://192.168.0.32/static/webassets/packed_libs.js?1fe9f29c line 131 > Function:3:58
Whatever I do.
Whith the spinning Save button of the death.
