Hi, sorry for bothering, I cant figure out why these errors happen, been trying to figure it out for over two days with no luck and I really don't understand what's happening:
Could not bind view model SettingsViewModel to target #settings_dialog : ReferenceError: Unable to process binding "click: function(){return testSensor() }"
Message: testSensor is not defined
Could not bind view model filamentsensorsimplifiedViewModel to target #settings_plugin_filamentsensorsimplified : Error: You cannot apply bindings multiple times to the same element.
Here is my jinja template:
<h3>{{ _('Filament Sensor Simplified') }}</h3>
<form class="form-horizontal marginTop">
<div class="control-group">
<div class="marginBot">
<b>Which Raspberry Pi pin your sensor output is attached to (-1 disables the plugin)</b>
</div>
<label class="control-label">{{ _('Board pin number:') }}</label>
<div class="controls" data-toggle="tooltip">
<input id="pinInput" type="number" step="any" min="0" class="input-mini text-right"
data-bind="value: settings.plugins.filamentsensorsimplified.pin">
</div>
</div>
<b>Input terminal of the sensor (switch) needs to be connected to ground or 3.3 V</b>
</div>
<label class="control-label">{{ _('Sensor is connected to:') }}</label>
title="{{ _('Specify how the sensor (switch) is connected. One end of the sensor must be wired to ground or 3.3 V. Sensor is triggered when open.') }}">
<select id="powerInput" class="select-mini" data-bind="value: settings.plugins.filamentsensorsimplified.switch">
<option value=0>{{ _('Ground') }}</option>
<option value=1>{{ _('3.3V') }}</option>
</select>
</div>
<div>
<table style="margin-left: 180px; margin-top: 20px">
<tr>
<td>
<input type="button" class="btn" data-bind="click: testSensor()" value="Test sensor">
</td>
<td style="padding-left: 10px">
<p id="sensor-test-result-text" data-bind="value: testSensorResult" style="display: inline;"></p>
</td>
</tr>
</table>
</div>
<div class="alert-info wy-alert-warning marginTop">
<span class="icon-info-sign"/>
<span class="octoFontFamily iconIndent">Sensor is triggered when open.</span>
</div>
<div class="alert-danger">
<span class="icon-warning-sign"/>
<span class="octoFontFamily iconIndent">Warning! Never connect the sensor to 5V! 5V could destroy GPIO of your Raspberry Pi.</span>
</div>
<div style="font-size: 11px">
For more information click <a
href="https://github.com/LuckyX182/Filament_sensor_simplified">here</a>
</div>
</div>
</form>
and here is my javascript file:
$(function() {
function filamentsensorsimplifiedViewModel(parameters) {
var self = this;
self.settingsViewModel = parameters[0];
self.testSensorResult = ko.observable(null);
self.onDataUpdaterPluginMessage = function(plugin, data) {
if (plugin !== "filamentsensorsimplified") {
console.log('Ignoring '+plugin);
return;
new PNotify({
title: 'Filament sensor simplified',
text: data.msg,
type: data.type,
hide: data.autoClose
self.testSensor = function() {
$.ajax({
url: "/api/plugin/filamentsensorsimplified",
type: "post",
dataType: "json",
contentType: "application/json",
data: JSON.stringify({"command": "testSensor", "pin": $("#pinInput").val(), "power": $("#powerInput").val()}),
success: function (result) {
if (result.triggered === true) {
$("#sensor-test-result-text" ).css( "color", "green" );
self.testSensorResult("OK! Sensor detected filament.");
} else {
$("#sensor-test-result-text" ).css( "color", "red" );
self.testSensorResult("Fail! Sensor triggered (open).")
// This is how our plugin registers itself with the application, by adding some configuration
// information to the global variable OCTOPRINT_VIEWMODELS
ADDITIONAL_VIEWMODELS.push([
// This is the constructor to call for instantiating the plugin
filamentsensorsimplifiedViewModel,
// This is a list of dependencies to inject into the plugin, the order which you request
// here is the order in which the dependencies will be injected into your view model upon
// instantiation via the parameters argument
["settingsViewModel"],
// Finally, this is the list of selectors for all elements we want this view model to be bound to.
["#settings_plugin_filamentsensorsimplified"]
What am I doing wrong? Any help is greatly appreciated...
