If you're suggesting that something on the printer's LCD display is now missing then OctoPrint wouldn't have anything to do with this. It sounds as though you might have upgraded the printer board's firmware at some point.
Hi
You need to update the firmware and the screen separately.
I recommend this firmware https://tinymachines3d.com/pages/10spro on there is a link for the V2.
Do you also have the problem that you need to re level every time you switch it on ?
@Ewald_Ikemann, I did, just wanted to know if the TM machines firmware solved it, as my printer otherwise is working very well and would avoid to touch the firmware.Thanks
