Hi! Today I started with 3D printing on my Ender 3 V2. Printing runs perfectly fine, that's good
Now I set up Octopi on a RPi 4 and got the warning about the broken Firmware. So I updated the Firmware (to 1.0.2). I also installed the "Creality 2x temperature reporting fix". It loaded correctly and is visible in the Plugin Manager. When I watch the terminal window, it still reports the temp in this format:
Recv: TT::25.5125.51 //0.000.00 BB::28.4928.49 //0.000.00 @@::00 BB@@:
and it does it aaaall the time. Should this (apart from the wrong format) be the case, that it is logging it all the time? Also temp report blocking does not work (maybe due to the fact that it is not recognizing it as a temp log).
So can you please help me? Or should I not be worried about it? It basically doesen't bother me NOW, but maybe in the future when I want to go deeper into some settings an terminal commands. Please help, thanks!
