Dashboard - no longer displays RP info after upgrade to pyton3
Greetings!
I appreciate that the Dashbord plugin is no longer supported. After I recently upgraded to Python3 the plugin no longer gives any CPU info form the RPi unit. Running OctoPrint 1.4.2 *Python 3.7.3 OctoPi 0.17.0.
Others seen this? I have the appropriate "show RPi system info" checked in the widget tab.
Any other thing to check or is there another plug in to install thar displays Rpi info?
I had noticed that the RPi info wasn't displaying around the time I upgraded to Python 3 but hadn't spent time investigating. TBH I had made some other changes around the same time and wasn't sure if I had caused the problem.
I've just updated the Dashboard plugin to 1.15.0 and the RPi information is now shown.
Perfect!
Just updated and all is working fine!!!
Many thanks for your prompt reply and fix Gordon!!
