DisplayLayerProgress plugin shows times in BST or GMT and not in my local timezone. How do I set it to use my local timezone, or subtract 5 (ie EST for me) from the estimated_end_time in order to get the correct end time for me?
Not sure specifically (I don't currently have this installed) but in my plugin (WS281x LED Status) it uses the raspberry Pi system time, and I tell users this can be set via SSH using the command sudo raspi-config, then select timezone.
If you are not using a Raspberry Pi, then find some way of setting the system time.
Thanks, that did it.
