I've turned on serial logging. I'm watching to see if a filament runout sensor plugin sends my GCode to the printer. If it does, will it show up in the serial log file?
Thanks!
Thanks!
I'm fairly certain it would, depending on how you are sending the commands and what commands you are sending.
why not test it?
Don't rely on what someone says or thinks will happen, actually put a short length of filament in, start a print, wait for it to fail, check the log file.
What is the cost of that?
Will it break anything you can't fix?
If the answer to those questions are : "very low", and "no" or "nothing important"  then just do it.
You can't beat actual data....
