Hey community
I´m new in this forum. Mein real name is Willi. I´m 63 years old. My primary hobby is programming. My first question:
I got installed the Plugin "Dry Run". If I start this, the printer will make a Bed Leveling, and stand still on front left. All right?. If I push the print button, i get a message like this " Extruder temperature is low". What did i wrong?
LG Willi
Hello @Kucky!
For investigations we need some more informations: Your printer, logs, printer firmware, OctoPi version, OctoPrint version.
Welcome Willi
click on the word logs for further instructions
Sorry,
After the next attempt, I send the log. Stood yes in the rules.
Sorry for the delay. This is the LOG.
12:25:59 probe at 20.000,79.000 is z=5.757500
probe at 20.000,79.000 is z=5.765000
probe at 114.000,79.000 is z=5.785000
probe at 114.000,79.000 is z=5.787500
probe at 198.000,79.000 is z=5.857500
probe at 198.000,79.000 is z=5.850000
Making the following Z adjustments:
stepper_z = -0.077117
stepper_z1 = 0.083434
probe at 20.000,79.000 is z=5.812117
probe at 20.000,79.000 is z=5.807117
probe at 114.000,79.000 is z=5.787117
probe at 198.000,79.000 is z=5.802117
stepper_z = 0.006555
stepper_z1 = -0.007822
Extrude below minimum temp
See the 'min_extrude_temp' config option for details
12:25:59 Extrude below minimum temp
12:26:00 Unknown command:"M108"
I don't know, where command M108 cum from.
LG Willi
P.S. I use Klipper Firmware
Hi @Kucky,
see https://github.com/KevinOConnor/klipper/issues/1009 for the M108 issue
(short: go to octoprint-settings / serial connection / behaviour-tab, bottom M108 checkbox)
I am not a Klipper-Expert, but maybe the firmware doesn't allow printing without heating up the nozzle. So, just dropping gcode for heating (like the plugin did) doesn't work.
Could you find a config option in your printer settings for See the 'min_extrude_temp' config option for details? Try to set this to 0.
BR
Olli
Thanks OllisGit.
I think also. I will d uninstall the PlugIn. I think, i don´t need it. If I'm an expert, I'll try it again.
Happy Holoidays.
Willi
