Nah. Not really. I built it in for situations like this, core or plugins having to store user specific data. Might make sense to create some sort of namespacing in there though.
I've got a few that I'd like to store in there for this particular design. I can throw you a preliminary list next week if you'd like but it's almost set in stone at this point.
How about {'pluginid_favoriteCookies': 'Do-Si-Dos', ...} for namespacing?
Yesterday, I swear this was working by directly calling the changeUserSettings() function. Woke up this morning and that didn't work. So I re-tooled things to call the REST API. It acts like it works but it doesn't write the information to the file itself.
# key in this context is 'michael', value might be 'MB'
userSettings = op.obj._user_manager.getAllUserSettings(key)
userSettings["plugin_ID_fullName"] = str(value) # Needed str() since it was trying to do u'Something'
u = json.dumps(userSettings)
r = requests.patch(api_url, u, headers={"X-Api-Key":api_key,"Content-Type":"application/json"})
# r.status_code will be 200 as expected
# Calling it directly instead of using the REST API worked yesterday but not today
#op.obj._user_manager.changeUserSettings(key, userSettings)
I'm seeing that behind-the-scenes there is a UserManager class as well as a FilebasedUserManager. I've reviewed my current and past octoprint.log files and they have no references to ...falling back to FilebasedUserManager! in them.
The biggest difference I can see is that Postman uses the hostname (and some IP address) rather than localhost and 127.0.0.1.
Update: I tried this using the hostname but that didn't help. I've converted this into the standard plugins settings storage and it's now working as expected.
