Hello,
I'm new to using using a raspberry and octoprint.
I did manage to get octoprint and the enclosure plugin working.
Only the enclosure temperature reading won't work.
I'm using a DHT22 sensor
I did have a readout in the terminal.
Does anyone have an idea how I solve this.
Hello @Joachim_Cappon!
DHT sensors sometimes ara a bit picky:
I also have a DHT22 connected: Sometimes is works, sometimes not
That is a common problem covered in the troubleshooting guide in the plugin wiki on Github. I had to disable "use sudo" under the advanced section of the enclosure plugin settings.
Unchecking "use sudo" is the solution to my problem.
Thx
