I am currently having trouble getting my filament / jam switch working with the enclosure plugin. I have tried to search the forum and google with no luck. I even ended up doing a fresh instill of OctoPrint on my Pi. Any help or advice would be great.
-N/O Switch connected to board pins 9 and 11 with the enclosure plugin in board mode
-Jumper pins have been tested with milti-meter and a connection is made when no filament is present in the switch system.
-I have run the printer in dry mode while watching the terminal and nothing happens when I remove the filament triggering the switch.
-Recommended setting were followed including (Pull Up) and (Fall) with in the enclosure plugin.
Feel free to ask any questions you may have. This is driving me nuts. I have PSU and LIght control working with out a issue so I know my GPIO Pins work.
