Enclosure plugin button not worked
I downloaded the enclosure plugin to control the light.
There is an output button at the top, but it does not change to on when i press the button.
I have had the experience of making this a success.
But it doesn't work all of a sudden.
I think it should be switched on and off regardless of the raspberry pie when I press the button on the homepage.
I reinstalled the octopi firmware.
μ•ˆλ…•ν•˜μ„Έμš” μ„±ν›ˆ.
Can you please share the Enclosure Plugin settings you made and the connection to the hardware (GPIO).
Output Type : Regular IO
Label : Output 1
IO Number : 4
I connected Raspberry pi GPIO4 pin to relay.
So, referring to the graphic, it's pin #7 on the connector. That's ok.
Can the relay board handle 3,3V control voltage?
The Enclosure Plugin has some advanced options.
In your case, take care that the Use Board Pin # check box is unmarked.
Use Board Pin # check box is marked.
My relay board handle 3.3V control voltage.
Same Relay is being used for PSU CONTROL.
And PSU CONTROL button is worked.
If I give you my address, can you check enclosure plugin button?
If you have the Use Board Pin # box marked, than you have to use 7 as IO Number.
