Enclosure plugin no temp showing
hello
I have used a dht22 sensor and installed all Libraries and when I run the test files i get a correct response..
but in the octoprint plugin i can´t get it to show nothing other then 0 in c and humidity.
any advise I have tried disableing sudo but nothing helps..
thanks
Thyge
Hello @Thyge_Hertzum !
I also had issues with the DHT22 and the Enclosure plugin.
You may try this plugin:
can it control a fan for a steady temp in my enclosure? because that´s actually the only thing i need it for...
thanks
Afaik: No.
Then you may try a different sensor.
Did you ever find a solution to this? I am having the same problem now.
Obviously not. Else this Thread would be marked with a solution.
Instead of zombify an old thread, you should open a new one.
