I think you're right, some how the temperature offset for the colour I was using was way out of whack, something must of got messed up.. thanks so much for pointing that out!
I think thats the solution!
I think @foosel might be right.... Found this:
Seems if you apply a temperature and/or an offset to your filament, then it adds both to the slicer set gcode temp? Might be something to check
Ahhh! We posted at the same time. Good to hear the issue is fixed!
@foosel Thanks so much for the help, as well @Charlie_Powell your assistance was appreciated!
